Question about Brother ML-300 Typewriter
How do I install correction tape - Brother ML-300 Typewriter
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around in there and you will find a manual.
DickyO
Posted on Oct 06, 2010
HOW DO I INSTALL THE CORRECTION TAPE? CAN'T GET IT TO CORRECT TYPING.
Theres a manual here that should tell you everything you need to know.
Dec 05, 2014 | IBM Correcting Selectric III Electric...
The correction tape wont stay
First make sure it is installed correctly as well as the ribbon. If they are not in their guides correctly, then this is common. Also, make sure you have a non-tacky correction tape or nearly non-tacky correction tape. Sure hope this helps.
Sep 10, 2013 | Brother SX-4000 Typewriter
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
I am having problems changing the correctable ribbon. It does not correct after installation.
if it prints but doesn't correct, it is probably a problem with the correction tape. make sure the tape is instaled in the correct postion with the dull side towards the paper
Mar 14, 2011 | Brother GX-6750 Typewriter
I installed new correction tape, but there's too much play in it. It keeps unravelling. I have no idea how to tighten it up. When I turn the take-up spool, it just unravels it more without tightening...
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons).
Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
Dec 27, 2010 | Brother ML-100 Typewriter
Installed a corrective ribbon on a SL480 typewritter, now I can't get the ribbon back on.
Sounds like the correction tape is not installed properly. Try remving and reinstalling it again. Make sure the hammer solenoid assembly is latched to its home position. After installin the correction tape you can manually operate the lift arms to check the feeding of the tape. If you have a loca dealer you can probaly take your machine to them and they may install the tape for you at no charge.
Nov 15, 2009 | Smith Corona Office Equipment & Supplies
The correction tape isn't working. it's installed properly, i think, but it doesn't erase anything.
Try taking the tape out and re-installing with the "dull" side towards the paper...if that doesn't work try a new correction tape.
May 29, 2009 | Olympia Mastertype 3 Typewriter
Installation of correction tape on Brother typewriter Sx4000
I installed the supply reel first, with the tape coming off the top of the reel toward the first guide, made a partial twist to the right to go over and around the first guide toward the take-up reel and then installed the take-up reel so that the tape goes over the top of the take-up reel toward the operating person and is then wound counter-clockwise around the take-up reel.
Mar 19, 2009 | Brother SX-4000 Typewriter
Installing correction tape
The full spool goes on the L. side of the printer it goes thru guides on both sides of the printer and thr empty goes on the R.
Be sure the dull side of the tape faces the paper.
DickyO
Aug 28, 2008 | Brother ML-100 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Brother ML-300 Typewriter Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
