Question about NEC APC Smart-UPS 3000 RM 3U (050-01800-000) UPS System
Powered from a generator the APC 3000 UPS running on AC power and running on battery lights come on alternately
  • NEC Master
  • 17,130 Answers
It is possible that the auto power detect section has gone faulty and is switching in this shunting manner because of an error in the line detect section. The op amp is detecting a low voltage to switch on and doing so it goes back to power. This can be due to a frequency problem in the AC generator and so If you switch off the generator the fault must stop.
If so have the generator checked for frequency change or the UPS has a circuit error. Try to set the AC voltage of the generator up to the required level if there is a drop on load.
Posted on Sep 28, 2010
APC Smart VT 30KVA UPS cannot sustain power after power failure
ups units run a computer directly from mains power and from a battery when mains power is cut.
some run the computer through the battery at all times and so use the battery as a surge protection
points to check on your unit
is the by pass system being damaged in the surge protection section
is this requiring the batteries to provide power but not being charged at the same time
Is the power consumption exceeding the battery rating ( pc, printer, monitor , modem etc exceeding the out put of the ups
Apr 27, 2015 | American Power Conversion Corp...
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
SUA3000RMI2U won't carry load
Did you run this test without AC input?
Also what happens when you cut off the AC mains without any load connected to it? Will the UPS continue to run or does it switch off as well?
Dec 15, 2012 | APC Smart-UPS 3000VA USB & Serial...
Hi my APC 1500VA smart UPS show overload without any load in battery mode, but when switched on AC power all lights are blinking. plz describe me how to resolve this Issue?
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
May 06, 2010 | APC Smart-UPS 1500VA Shipboard...
Ups not working on generator power
you will try to change the fuse in ups
Aug 24, 2009 | APC Back-UPS CS 500VA UPS System
Apc ups legwerkin
Your Generator is not supplying a clean enough AC voltage and the UPS is unable to handle it.
Some Gennies supplies are very rough especially the cheaper end of the market.
The likes of Honda do conform to as near to cable fed mains as you can get.
You may be able to get a filter which will smooth out the ripple effect on the Gennies supply so you would power the UPS from the filter and the filter from the Gennie
Jun 16, 2009 | APC Smart-UPS 1000VA UPS System
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
Common Failure mode of APC 500 UPS
I would recommend replacing APC UPSs with ONEAC ONEPlus Power Conditioned UPSs, which have a perfect ground reference, longer lasting and more reliable batteries, and a 5 Year Warranty (2 Yrs on Batteries).
www.gryphon-inc.com
1-800-POWER-OK
Dec 04, 2008 | APC (BH500NET) UPS System
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
NEC APC Smart-UPS 3000 RM 3U (050-01800-000) UPS System Logo
356 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
