TV weight I need to know the weight of my 1986 Panasonic Model CT275f12t to know if it will fit on a TV stand that I have purchased.
  • HarrietFeldm May 24, 2008
    The TV is too heavy for us to lift on to a standard scale.
  • ever81 May 25, 2008
    do you know how much this tv weights?
Weight - in pounds - what is the weight?
Posted on Oct 04, 2008
The trick to lifting Large TVs' is that they are very 'front' heavy, that is, most of the weight is in the picture tube...recall the "problem" of unstable TVs' from years ago (Children pulling down TVs')
If the TV is on the floor you can put a large pillow at the front (Picture tube face) on the floor & carefully tip the set forward onto the pillow. You can then measure the bottom of the set to see if it will fit on your stand. If you are concerned about the weight simply attempt to sit your body (180 lbs?) on your suspect stand..if it holds your weight your good...wiggle around to see how stable it is.
_________________________________________________Rick......
Posted on May 25, 2008
I am shipping my tv to my new location, need to know the weight
Which model TV do you have?
The TVs in the LD-325 line are 14.55 pounds with the stand, but is 13.45 lbs without. If you have the original shipping container and all the accessories, the LD-3255VX weighed 21.83 lbs. The LD-3255AR is 23.2 lbs in the box.
The EW32S3PW with the stand is 15 pounds and 1.5 pounds lighter without the stand.
The older model SK-32H640G is 23.9 pounds with the stand. Removing the stand takes 1.4 lbs off the TV weight. When in the original box with accessories, the TV weighed 27.0 pounds.
There are a number of other models, so please add a comment with the model number and if the stand and accessories are going to be in the same box. I hope this gives you some help.
Nov 10, 2012 | Westinghouse 32" Flat Panel LCD HDTV
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
Toshiba 32D46 - Need to know weight in order to determine whether tv stand will support it safely.
Hello
Your Toshiba 32D46 model TVs weight and diamensons are
Width: 29-9/16 in. (751 mm)
Height: 25-15/16 in. (658.5 mm)
Depth: 21-3/4 in. (552 mm)
114.7 lbs. (52.0 kg)
OK
Jan 02, 2011 | Toshiba 32D46 32" TV
Do u know the dimensions of the rear projection/it quit working
These are the dimensions of the TV itself (including the bottom piece)
The height of the TV is 37.2 inches tall
the width is 49.6 inches wide
the depth is 17.4 inches deep.
the weight of the TV is 132.5 pounds (just thought you would want the weight as well if you are considering purchasing a stand)
I hope this helps and good luck!
Feb 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Trying to find a tv stand for this tv. what is the weight of the tv
  • Dimensions: 29" H, 30 1/8" W, 22 1/2" D
  • Approx. Shipping Weight: 120 Lbs. I would get a stand that gives you some extra capacity for safety. Measure the base of the TV so you know the dimensions of the sets "footprint" to know the dimensions you need for the stands shelf to accomodate the set. Good luck
  • Nov 25, 2009 | RCA F32648 32" TV
    Weight of TV
    near about 75 kg.
    Sep 19, 2007 | Proscan PS36500 36" TV
    Televison & Video Logo
    1,011 people viewed this question
    Top Televison & Video Experts
