Question about Square D Qo 200 Amp 42 Circuit Indoor Breaker Panel Box
I'm wiring a custom home and there seems to be a lot of feeds or hrs needed how do I know if a 200 amp service will be enough or do I need 2 200 amp panels?
  • 56 Answers
I need a liitle bit more info of the house. Total heated square footage and what appliances are electric?
Posted on Sep 29, 2010
I have a lincoln squarewave 175 and i cant seem to get a arc or wont stay on enough feels like i cant turn the knob for amprage and wont do anything
to increase the amperage or welding current you have to change the voltage setting. Higher voltage =more amps available . Check also the wire feed or rod size as this has a lot to do with the amps required.
Nov 13, 2014 | Cars & Trucks
Cost for a 200 amp circut breaker
Any home supply store can give you the local cost. An additional cost will be even greater than just changing breakers. You must also change out the incoming service drop conductors. There may also be a need to have the power company's transformer supplying you home changed out. Check it out to be sure.
May 31, 2014 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Viking emerald 116 sewing machine will not feed fabric
Look at the feed dogs (the serrated metal strips on either side of the hole the needle goes down thru). If they aren't moving when you turn the handwheel or not protruding above the sewing surface (needle plate) then 1 of 2 things has likely occurred.
#1 - your machine is equipped with at feed-dog drop selector (drops the dogs down for free-motion sewing) that you have activated (intentionally or not) or
#2 - you have enough lint debris accumlated under the sewing surface to stop the dogs from coming up properly or move all together.
Have the machine professionally serviced. A good servicing will resolve 60% of the problems that sewing machines incur. You should have the machine serviced at least every 100 hrs of sewing, more often if you use cheap thead, cheap fabric or metallic threads. All of these leave a lot of debris inside the machine.
Jan 05, 2014 | Husqvarna Sewing Machines
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Need hook up diargam for 240 volt 30 amp washer dryer residential xyo-gnd recepticals.now for free .like your web site said. or i will presume this is just a scam trying to lure people in for some...
Hi Watsonelecco!
No scams here... most of us on FixYa are like me.... we enjoy helping people out with their everyday problems. I work nights and do this as a hobby... I used to teach advanced electronics and Radar for the US Navy.
It is difficult for me to give you a diagram for "xyo-gnd" since the term is not familiar to me, even though I worked as an industrial field service engineer. My guess is that you need to connect your washer/dryer to your electrical outlet.
First thing.... I need to know where you are located, and what type of power service you have coming into your home. Most US homes are wired for 115 Volts and require a separate input for 230 volt appliances. Most European, Australian, and Asian homes are wired for 230 volts and connecting your washer/dryer will be simpler, but still require some work.
The first thing we will need to know is how the power comes into your home and how it is distributed. Look at your circuit breaker panel. You will have a mains coming in that feeds a 2 pole "main" breaker- it will be rated at between 100 and 300 AMPS in most homes.
Next... the other breakers in the panel.... how many are "2 pole" breakers (what looks like 2 switches connected together) and how many are single pole? Only a 2 pole breaker can supply power for your washer/dryer.
Now, you need to determine which of the two pole breakers are rated high enough for 30 amp service. If none say 30 amps or higher, you will need to install a new breaker and run a 10/3 AWG type UF cable to where you are installing the washer/dryer. Find a recepticle that matches your washer/dryer plugs, and install it with the black wire to the brass lug, the white wire to the silver one, and the green wire to the green lug.
Once you have the wiring done, you will be good to go!
If you already have a dual breaker rated at 30 amps supplying an outlet where you are installing the washer/dryer, match up the plugs/outlets the same way... black wire to brass, white to silver, green to ground. You may have to purchase either the correct outlet, or (more likely) the correct plug, since most units do not ship with power cords.
Apr 07, 2011 | Microwave Ovens
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
I Am installing a Generac 20Kw air cooled unit with a 200 amp service disconect ATS What size conductors do i use from the generators 100 amp breaker to the transfer switch
It is always good to install a large enough wire where the maximum load can be drawn plus a little extra for safety. 7 gauge wire will do, if it was mine I would use 6 gauge wire. If the length is over 20 feet but not longer than 80 feet go to the next larger size wire.
Dec 18, 2010 | Generac Guardian RTSE200A3 200 Amp...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Square D Qo 200 Amp 42 Circuit Indoor Breaker Panel Box Logo
Top Square Electrical Supplies Experts
Steve
Craig Butler
Craig Butler
Jim D
Level 1 Expert
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
