Question about Plumbing
When I turn on the faucet, the water "sputters" and hammers, getting worse as I increase the flow. If I turn on the faucet while turning on the spray nozzle, there is no sputtering and no hammering.
3 Suggested Answers
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 5603 Answers
SOURCE: When the water is turned on, the faucet
The USUAL cause of this is the diverter valve that channels the water to the sprayer. There are several types of these so search for yours in google to find a blow-up drawing of it. They are usually in the tower the spout swings on and sometimes are a pintle valve like a little rod with dumbells on the ends. Crud can make them not seat then they will cause the hammering.
Posted on Mar 09, 2010
I am getting no water from the hot side of all my faucets cold water works fine
Sounds like the water inlet valve to your hot water heater has been closed (turned off) If the tank has no water coming in, it can't put anything out.
Mar 21, 2015 | Plumbing
Brand new faucet thumps when turning on
you have air in line
1. turn off water under sink
2 turn faucet on full
3. turn on valves under sink water will sputter then run solid
Hope this helps mike
Nov 28, 2013 | Globe Union Glacier Bay 8 In Double Handle...
After trying to use sprayer in kitchen sink, now facuet will not work
The Faucet may be clogged with dirt, or screen is clogged.
Nov 15, 2013 | Plumbing
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
I HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN FAUCET THAT IS RESTRICTING THE FLOW OF WATER WHEN TURNED IN THE HOT POSITION. THE WATER IS FLOWING FINE IN THE COLD POSITION BUT WHEN TURNED TO HOT...
If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
Here is a good PDF source to do it.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 12, 2010 | Blanco Classic Single Handle Faucet with...
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
When the water is turned on, the faucet "sputters" and "hammers" as if the water had been turned off then back on when it hasn't been. Plumber says we need new part (inside cartridge 070807-Aqua Source)....
Mar 09, 2010 | Danze D403412 Melrose Single Handle...
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Plumbing Logo
364 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
