Question about Mtd Garden
HOW DOES THE VARIABLE SPEED (GEARS) OPERATE ON THE LAWNFLITE 548 RIDE ON MOWER
  • 376 Answers
SOURCE: Ground speed slows under pull at high variable speed settings.
Take off the plate around the shift lever between your legs and take a look at the belts. Most likely they will be in poor condition. You can even leave the trans in neutral, start the engine and move the speed selector through the gears and observe the belts in action. They do the same in neutral as in gear when you let out the clutch with the engine running. You should be able to see what the problem is, It will either be one or both of the belts or possibly the needle bearings in the vari-speed pulley itself,
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: Hi, Mum has a wtd wanrite mtt model 548/12hp mower ride
Hi this sounds like there is a spot of dirt in tne fuel system
you will need to dismantle the carburettor which is quite straight forward (be careful not to lose any screws or gaskets
guive the carburettor a good rinse in neat petrol/gasoline and blow out any debris that may be there.
re assemble the carburettor and prime with fuel and you should then be ok.
One other thought if you have found that the motor runs fine without being on the grass (eg it doesn't cut out after a minute or two) then it could be that you have the cutting blades set too low for your first cut. To raise the blade adjust the height of the wheels. Always start cutting with a high setting especially if the lawn hasn't been cut for a while.
hope this helps
W
Posted on Jun 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
Posted on Jul 20, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
SOURCE: lawnflite mower wont start. I have no response
Not a fix sorry, but i also have the same issue as you but im not as advanced as you... i've heard about the solenoid 'fix' but i simply dont know where to find it to try it... can you let me know where it is. Thanks
Posted on May 28, 2010
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
How to remove the rear wheels from a mtd lawnflite ride on mower
they just need bumped off after the bolt is removed .they will be rusty so some penetrating oil will help a lot
Feb 17, 2015 | Mtd Garden
Jerky movement
there are 2 drive belts that control the transmission. 1 is a variable speed drivebelt going from the engine back to the trans. it is the long one. the shorter belt drives the trans. off of the other variable speed belt. both belts are located under the mower and are not fun to get to. I would bet that one of these belts are slipping and grabbing, giving you the jerky ride. visually inspect for cracks or peeling, then check tensioning system for the belt to make sure they have the correct tension. less likely would be in the geardriven trans. it might act that way if some teeth of the gears inside are worn or broke. one other thing to check if all else looks good.... the variable belt drive pulley expands and contracts to change speed of the transmission input. I have seen these pulleys fail to operate correctly and this could also cause the ride to ****. hope some suggestions here help. R
Aug 23, 2012 | Toro Power Lawn Mower
What is the drive belt adjustment 11.5 hp ride on mower
The drive belt is tensioned by a spring on the clutch pedal. If you can give me the model of mower you are working on, I can help you find the spring or the variable speed pully.
Thanks, Matt
Jan 15, 2011 | Mtd Garden
Trying to replace ext spring on lawnflite 548 can't get the spring to stretch the last inch.
You don't specify which spring but if you take a piece of starter cord, tie it in a loop and hook it on the loose end of the spring, put in a long screwdriver, a piece of broom handle or anything similar, it will give you a lot more leverage to pull the spring. Once you get it to where it needs to go, you can maneuver it to get it hooked then just cut the rope and pull it out
Sep 12, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
I need to replace the transmission drive belt and need instructions
There's actually a Troy-Bilt Pony riding lawn mower as well.  If yours is like ours, a model 13AN77TG766 [URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf], it doesn't actually have gears but rather a variable-speed pulley.  The lever on the dashboard actually controls how high the brake pedal will go, while the brake pedal controls the position of the variable-speed pulley, which controls the effective gearing ratio.  That's how it can go at any speed with the engine still going at the same rate and without having to disengage a clutch.
So perhaps your mower is engaging the parking brake too early (page 17 of our manual).  The other thing I can think of is grass in the variable-speed pulley.  To check that, remove the spark plug and the battery (7/16-inch socket).  Then move the shift lever through its full range and check the shaft of the variable-speed pulley (part 63 on page 34) for debris, both above and below the loose plate thingy.  (You should be able to turn it quite easily if you put the forward/reverse lever in neutral.)
Hope that helps!
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
