Question about Sony Handycam DCR-SR300 Camcorder
Turn on camcorder, screen is black. move the screen to different positions, sometimes screen will go to normak brightness ans then the picture roles downward with a black horizontal line, then camcorder shuts down.
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 28, 2010
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
DCR-TRV255e Sony handycam shows black screen when recording. When inside and recording, the LCD and viewfinder are black, except for large sources of light. For example, everything will be black but I can...
I'm sorry that the Camcorder is displaying the error message. Please follow the troubleshooting steps provided below and check the operation:
1. Please insert a different disc and close the disc tray firmly.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://eservice.sony.com
Thank you for your time.
May 28, 2012 | Sony Handycam DCR-TRV22 Mini DV Digital...
My Logik TV has no picture - it has sound. It has been doing this since I purchased it 5 years ago after just over a year. I tried getting them to fix it but they looked at it and made it work for a...
  • lucky goldstar some re solderings activity special on some supression coils in the backlight inverter/power supply and a little capacity roling not always but maybe but its not an easy problem sometimes connecting fcc sheets trouble , sometimes wet cleaning of the screen made problem on contact sheets on the screen that will give some different troubles. search some hobby technical people who can repair it , but repair or patch up the problem are 2 different things in case of this kind of problems on LG flat panel screens
  • here some things to watch there are several options https://www.youtube.com/results?search_query=lg++flat+panel+screen+repair
LG 42LE5500 Service Manual
Jul 12, 2017 | LG 32LD550 32 in. LCD HDTV
POOR COLOR QUALITY, NO MATTER HOW BRIGHT THE ROOM. SOMETIMES CAMCORDER WILL CATCH THE COLOR, THEN FADE BACK TO DIM LIGHT
I'm sorry that the video quality of the camcorder is poor. Sony camcorders will automatically adjust the shutter speed based on the lighting conditions. When video is being shot in low light situations, the camera will slow the shutter speed. This is normal operation and is not a service issue. To prevent this issue, record video in locations where more light is present.
You may use the White balance feature and check the operation. Refer the page 71 for more information. Refer the URL to download the Operating Guide:
http://www.docs.sony.com/release/DCRDVD105-205-305.pdf
You may also perform a power reset and check.
Performing a manual power reset
  4. Remove the lithium button-cell battery.
  5. Move the POWER switch to the CAMERA position for 15 seconds.
  6. Move the POWER switch to the OFF position.
  7. Reinsert the lithium button-cell battery.
  8. Reconnect the AC power adapter or reinsert the battery pack.
  9. Turn on the camcorder.
Jan 04, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Screen goes black shortly after turning on
I'm sorry that the screen goes black shortly after turning on the camcorder. I suggest that you perform a manual power reset and check the operation. Follow the steps to perform a manual power reset:
Jan 04, 2011 | Sony Handycam DCR-SR42 Camcorder
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
My camera's monitor/screen is black with no picture
My AIPTEK 1080p was powering on but the screen was turning off within one second of turning the unit on. I verified that the camera was still working and just the output onto the screen failed. I was able to resolve this by hooking the camcorder up to the TV and viewing the menus on the TV and then turning the camcorder off with the power button. I think this problem happened because I didn't do a "clean" shutdown the last time I had my aiptek hooked up to the TV. It is now working perfectly!
Jul 27, 2009 | Aiptek Video Cameras
Black screen
when problems occures with monitor is always with picture tube but some time less brightness is also reason for black screen
check brightness of your system i think it should be on maximum level and brightness is perfact so i said problem with picture tube. may be picture tube is gone...
Mar 28, 2008 | Acer Aspire 5050-3242 Notebook
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Sony Handycam  DCR-SR300 Camcorder Logo
200 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
