Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD 710 D Transmission is pumping air from ?? Only
JD 710 D Transmission is pumping air from ?? Only way to stop it is over fill w/fluid. Oil smells burnt ,and 3 and 4 are slipping badly.
2 Suggested Answers
  • 3074 Answers
SOURCE: I have a jd LTR
Anything for a Deere is going to be expensive, here is the procedure and it not all that hard, just keep track of parts and tools, Tim :
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LT166_48CdeckLawnTractor.pdf
here is info on the tractor:
http://www.weekendfreedommachines.com/gallery/main.php?g2_itemId=89100
maintenance info:
Posted on May 15, 2011
VW CADDY 1.6 PETROL GEAR 5 COME OUT WHEN DRIVING.AND CAN'T LOCATE THE PLUG TO FILL UP GEAR OIL.THE GEAR BOX IS MANUAL.
Drive for 10 minutes or so to warm up the transmission fluid. Stop the car on level ground where you intend to work, and place your foot on the brake. Shift the shifter into each gear and hold it there for three to four seconds. Place the transmission in Park.
If you have access to a lift or a friend with a lift, then use it to raise the car from the ground. Otherwise, you'll need to use a floor jack to lift all four corners and secure them on jack stands. It's critical that the car remain level.
Locate the transmission and the two plugs. On the low right-hand side -- passenger side -- of the transmission you'll see the drain plug. On the front, upper left-hand corner you'll see the fill-check plug. Remove the fill-check plug with a wrench; if the transmission fluid is up to level, a small amount will trickle out. Use a hand oil pump, with one tube in fresh tranny fluid and the other in the check-fill hole, to refill the transmission with fluid. It's impossible to overfill -- just stop when fluid starts to trickle out of the check-fill hole.
Nov 30, 2017 | Cars & Trucks
How to change auto transmission fluid of ford everest
Just draining the fluid does not get the fluid out of the torque converter. Most service shops use a machine that replaces the fluid while the engine is running and uses the pump in the transmission to move clean fluid in while at the same time collects the old fluid. That is , by far, the best way to change ALL the fluid in the transmission
Dec 13, 2014 | Ford Cars & Trucks
What kind of lubricant should I use in the transmission of a John Deere 165 Hydro?
I grew up with John Deere's and worked at a shop assembling Cub Cadet's way back when.
From all the threads I have read..that's an Eaton Transmission.
You can actually use a good SAE 30w motor oil in it. . some folks use a 5-20W or even Dex/Merc universal AT..but the general consensus is a decent 30W motor oil. Cheap and easy to find.
This is not an actual hydraulic motor, so any of these oils will work. Not to forget JD has HyGuard.. which is similar to the dex. Keep it simple and Stick to the SAE 30W..
Clean tranny off to prevent debris from entering the case.
Remove fill plug and Drain plug
Drain when warm
Replace drain plug
Remove vent plug
Fill until oil appears at vent hole
Rotate axle to remove trapped air
Check fill level
Replace vent plug and fill plug
GO go go
Mow mow mow
Best of luck
May 01, 2011 | John Deere Garden
Where is this filler plug for an aoutomatic tranmisson
You have to pour the transmission fluid down the dipstick tube. You will need a funnel to put in the dipstick tube.
Feb 15, 2011 | 1996 BMW 318
My car as i come to a stop it wants to not down shift automaticlly it'll **** and want to cut off until i tap the gas.My oil light wants to come on by then.I've replace the oil,oil filter,transmission...
If your transmission fluid or filter had any metal shaving or smelled "burnt" this would definately be a cause for the transmission from not shifting properly, also check to see that it is full and fill if necessary without overfilling which would ruin it quickly. Oil light coming on in old pontiacs and gm's is due to low oil pressure usually from a worn out oil pump or even a clogged screen on the oil pumps pick up tube. An old trick in transmissions was to take about an oz of dot3 brake fluid and add it to your transmission fluid to increase viscosity which helps slipping and minor seal leaks for a temporary fix. As to your vehicle wanting to stall out when you stop you may need a tune up or to advance the timing and increase your idle speed a little to correct that.
Dec 10, 2010 | 1986 Pontiac Parisienne
How to drain and put new transmission oil on my chevrolet aveo 2005 manual transmission?
you dont ---end of story it should never need changing on a modern vehicle ,unless you take the drive shafts out to do a clutch then you top it up through a filler plug at halfway level on the gearbox ,Dont make work .
Aug 17, 2010 | 2005 Chevrolet Aveo
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
Automatic Transmission, Total Fill
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
What fluids do we put underneath the truck clutch fluid? Or is there something else we need to know? This is after replacing the whole clutch. When the new cluth was put in fluid came out is that clutch...
The fluid used in the hydraulic clutch line is brake fluid.
The fluid used in the transmission can be either 10w30 oil......80w90 oil or automatic trans oil ....it depends on what transmission you have and what year you have.
Some transmissions are filled through the shifter opening.
Do not overfill it.....it will leak out on your new clutch.
Sep 27, 2009 | 1988 Mazda B2200
How do i check the transmission fluid
transmission fluid you can check easy way the gear box is one oil to be so you can see in the middle of the gear box filling plug remove that with spanner if you see oil coming from hole that is fine you don't put more just putted back and tight. if you don't see any oil just use your finger front part through if the front part of your finger touch the oil that is also fine means ok. but is the oil is very low from that place you must fill.
To get the level if you fill the oil you stop filling when you see oil is draining so you wait until oil stop clean the aria then you fixed back the filling plug or bolt tight.
that is my advice sorry any mistake of my tipping.
Oct 26, 2008 | 2003 Oldsmobile Alero
Is there another tool besides a hand pump that we can use to put transmission fluid in the fill plug?
use an old school oilcan...the type you fill with oil of your choice, and has a finger pump action (like a squirt bottle). you should be able to pick one up with a flexible spout at any reputable auto parts suppliers.
Jul 22, 2008 | 1999 Isuzu Rodeo
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
50 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
