Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Model DH102 Leaking water from under Dishwasher'
  • Tricity Bendix Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
qw36q
Posted on Sep 29, 2010
Tricity bendix model dh102
It's either an intake valve just where the hose meets the machine or a bad pump.
May 22, 2014 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Apr 05, 2013 | Whirlpool Dishwashers
Dh102 not letting water in to start cycle
check the valve and the outlet to fix properly. or check with the service technician. thanks
May 20, 2012 | Tricity Bendix 24 in. DH102 Free-standing...
DH102 will not drain of water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Tricity Bendix 24 in. DH102 Free-standing...
Will not run groaning no water entering machine
Could be a bad water inlet valve or overflow float switch stuck or debris caught under float preventing it from closing the float switch. It could also be a bad timer.
If the noise you hear is a humming sound, it is a seized motor.
Hope this helps.
Aug 14, 2009 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity bendix dh101
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
If you enter model number here , you can find parts and diagrams.
Nov 03, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Water will not fill
Check also the door switch, if that is stuck or defective, the machine won't start the cycle.
Aug 01, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity Bendix DH101 dishwasher
my tricity bendix dh101 will not fill up with water what could be the problem
May 09, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwasher not emptying the water out
If you find no problem, you may need to replace the pump.
Apr 06, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
211 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
