Question about Whirlpool LER5636P Electric Dryer
Doesn;t start when the button is pushed - Whirlpool LER5636P Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 28, 2010
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
Feb 24, 2013 | 2004 Volvo XC70
Bad switch on Electric Started
hello,if it is the one i think it is to where the push button is a closed unit with no screws as far as i know there is no repair for the push button switch,how ever there is a good how to on u tube repairing snowblower electric starters,from what i have seen the push button doesn't go bad,now if the push button comea apart you can repair it which useally the black box or circut thing that cost around $40.00 found on most s 200 blowers,hope this helps,,
Jan 23, 2012 | Garden
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The printer will not start when you push the start button. It is a new printer
Most likely, this issue might be caused by Start button being stuck. If you can't turn the product ON by pushing the Start button, double check if the Start button is somehow stuck, and also make sure that the unit is firmly plugged in to the wall outlet. If that doesn't resolve the issue, try a different outlet because you might be experiencing power outage on the outlet where it's plugged in. If that won't resolve it, I'm afraid the unit has to be serviced.
Apr 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
