Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Briggs n Stratton 17.5 craftsman rider. It started to blow gray smoke. Oil was filling up w/ gas. I change carb and oil. Still blowing gray smoke. Loosing oil. Thankyou in advance
  • 2,299 Answers
You have a blown head gasket. The gasket is leaking the fuel into the oil. You will have to replace the head gasket.
Posted on Sep 28, 2010
Vanguard briggs and stratton 14 hp engine blowing oil out of the air filter what can it be? did change the head gasket.
broken oil ring compression ring ok just broken oil ring letting oil pass to blow out intake should have light smoke to coming out
Sep 23, 2014 | Briggs & Stratton Garden
280H07-0166-E1 briggs engine blows smoke out exhaust
smell the oil if it smells like gas then the needle and seat in the carb is leaking if not remove the cylinder head and see if the gasket blew out and its sucking oil from the crankcase if not look at the bore for scores scratches and scraps
Aug 13, 2012 | Briggs & Stratton Briggs Stratton...
Why is my 22 hp 42 inch deck craftsman rider mower oil leaking somewhere in th fron of the engine
i need more info where is the leak near also check oil level if its to full it will blow by to the intake
Jul 29, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Oil blowing out of carb. gas in oil ohv engine
carb needle valve stuck open clean carb possible bad float dont run with gas in oil
Jun 23, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Getting fuel in oil on 19hp b&s motor. Cleaned carb and drained oil, fresh oil and started motor, motor ran for 3 or 4 minutes then had to use a little choke to keep running and then it started...
How long did it take to do this job..did you clean the the carb first...then the oil or vise versa...the reason I as is ma y if these motors are equipped with an electric valve on the carb that go bad or stuck allowing the gas to continue flowing after shut down eventually in the intake valves and into the crankcase...causing smoke and high crankcase pressure and out the carb and exhaust...no use changing it WILL happen again..the fix is simple put an inline gas shut off and shut it off if only shut down for minutes...happened to my 18 horse Briggs...just shut it off every time you turn the engine off..Hope this helps..good luck..
Sep 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
After trying to run a water hose through it to clean my Toro 650 190 CC lawn mower has refused to start for me, let me add before the hose I turned it upside down to get out excess grass, Now I've...
Only tilt a lawnmower backwards toward the handle end (spark plug end raises) Other ways move the oil around to places it doesn't need to go. Now you probably have gas in the oil....check it or change it (milky looking or smells like gas..contaminated...might need changing anyway...You probably will have oil in the carb and it will blow smoke...You probably filled the oil breather with oil and it will drain down...causing smoke also. This was the wrong thing to do A 2 year old unit should be mechanically sound..Check the air filter, spark plug and carburetor for oil fouling. Remove the bowl on the carb to help get some of the oil out...it will leak gas when you do.
Jun 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
586 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
