Question about Bosch HBN 430560B / 430520B Single Oven
Bosch oven won't pre-heat/heat with door closed
My Bosch HBL 645 oven intermittently will not heat up with the door closed. If I leave the door open an inch or two it will heat up. Any clue what may be causing this and how to fix it?
  • 36 Answers
Hi ,
according to me ,there is some issue with the cables that are connected the heat functionality of oven , because the same happned with my lg microwave , then the tech checked it , it was a cable fault , one of the cable was loose when the door was fully closed microwave was not working but when we leave some space while closing it it was working , so it is recomended if your oven is in warranty the call the company technicans to fix it , plase dont try if dont have expertis on it take help of tech who knows about microwave
Posted on May 24, 2008
  • 3,037 Answers
Hi Juliogags,
It seems that your that the sensor in your door needs to be replaced or repositioned. This will require taking apart the oven no doubt to locate and fix this problem. If you want to do it, make sure the power is off before attempting to take it apart from the back.
Let me know if you have any more questions and I will be here to help along the way.
and good luck
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
  • Bosch Master
  • 19,396 Answers
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
  • Ginko
    Ginko May 24, 2008
    Check also that the problem is not that:
    the oven start warming up then stop before reaching temperature, then it restart after a while once you open the door, as temperature inside cools down.
    In this last case is the temperature sensor inside oven to be replaced.
Oven heats slowy
Most often this would happen if one of the heating elements isn't working to pre-heat the oven.
Nov 07, 2013 | Bosch HBL 445 Stainless Steel Electric...
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL 645 oven door won't close all the way
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Jan 04, 2010 | Bosch Ovens
Bosch double oven, the bottom door won't close all the way
This requires door hinges to be replaced,relatively simple job & parts cheap.Best buy parts from Bosch direct .
Mar 15, 2009 | Bosch HBL 5056 Electric Double Oven
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch oven door does not close tightly, takes FOREVER to heat
All you need to do is replace the oven door hinges. as the springs are weak.
It is a fairly straight forward repair to do.
To obtain new hinges, got to:
www.bosch-spareparts.co.uk
or
www.espares.co.uk/bosch
Plz rate my solution.
Thankyou.
Jan 05, 2009 | Bosch HBL 745 Stainless Steel Electric...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBN 430560B / 430520B Single Oven Logo
621 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
