Question about Admiral AAV7000A
Admiral washing machine AAV7000AWW won't stop filling or agitate?
Admiral washing machine AAV7000AWW won't stop filling and overflows. When I manually turn ther timer to make it stop then it won't agitate. I can turn it to the spin cycle and it will spin and drain.
Thanks,
crcrider
  • crcrider May 24, 2008
    Also when it's ending the spin cycle it makes a loud squeaking noise. Also can i replace the inlet valve and program timer?
  • Admiral Master
  • 19,396 Answers
It is either the inlet velve or the cycle programmer faulty
Posted on May 24, 2008
  • Ginko
    Ginko May 24, 2008
    If the problem is due to cycle not automatically progressing then it is likey to be a cycle programmer problem, you should change the programmer or the whole control panel, depending on the model.
  • Ginko
    Ginko May 24, 2008
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
Admiral washer aav7000aww-agitator only spins one direction-doesn't agitate-it stirs the laundry.
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
Here is the transmission to order if you should find it bad.
Sep 26, 2013 | Admiral AAV7000A
Admiralwasherm#aav7000aww fills up just humswont agitate
Possible that the motor is not starting up as the starting capacitor to the motor is weak. check if the motor is warm after switching off power. if so it is confirmed. Otherwise it can be due to a belt issue, bearing failure and jamming of the agitator and shaft.
check power to the motor during the wash cycle to confirm , if not the control unit is a suspect.
Jul 05, 2012 | Maytag Admiral AAV7000A
Water overflowing from Wasing Machine AAV7000AWW Admiral
this is 1 of 2 problems. either the pressure switch is no good or the pressure switch hose has a hole in it causing the air pressure from triggering the switch. locate the pressure switch and pull the hose off the end. start the washer and try to blow into the end where the hose was connected. if the water stops then you will need to replace the pressure switch hose. if the water doesn't stop coming in then you will need to replace the pressure switch
Jan 01, 2009 | Admiral AAV7000A
Water fills to overflowing without stop
replace the hose ..connects to tank other end goes under console to water level switch so no level control
Nov 16, 2008 | Admiral AW22 Top Load Washer
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Sep 01, 2008 | Admiral AAV7000A
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
Admiral AAV7000A Logo
418 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
