The door will not open post the wash cycle.I have allowed over 15 mins to pass but the door remains locked shut.the machine is an lg intellowasher dd.
  • MrJeff May 26, 2008
    Thank you for your assistance.I have found the source of the problem. The door was assembled incorrectly at manufacture so that depressing the handle forced the plastic clip of the door handle mechanism to force the lever aft, thus unlocking it. However the excess force required each time to open the door caused the plasic clip to break.Hence the lever was no longer pulled to the rear. A new handle has been ordered for a cost of £10 and can be easily fixed with the removal the door(4 screws). Once i have the new handle the whole job will take less than 20 mins to sort.
  • Anonymous Dec 23, 2008
    DOOR MECH ASSEMBLY
  • 868 Answers
Un plug the power cord and let it sit for a while,then plug it in.
Posted on May 24, 2008
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
Sharp washing machine won't unlock door
I was going to suggest switching t off for a while, allowing the thermal lock to release.
Mar 22, 2014 | Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
THE DE ERROR CAME ON MY WASHER WHAT DO I DO/
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening
If happening in mid cycle power of the unit and remove the power cord and wait for 5 mins.Then plug it. Check whether the door opens if not you require the service people
Check anything is caught on the washer door.
If you passed it they door may not open if the inside water is warm.It is a safety feature.It unlock after sometime
Thank You
Sep 09, 2010 | LG WM-2077C Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Hello. I have an LG intellowasher front loader wd-8015c which has finished its cycle but the door will not open.... how can I get it to manually open? I have tried doing another rinse cycle and pumped out...
If you've waited the normal time for the interlock to allow the door to open and it's still locked, the interlock switch itself is probably faulty. Tricky job. Best to find a repair technician........Nomess
Apr 18, 2010 | Washing Machines
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
