Question about Frigidaire Cooktops
I have a glass top stove and when I use my big front burner I can smell something electricall hot.What is a possible problem and can it be fixed???
  • bopbirds Sep 29, 2010
    I just found the manuel but no number ,it says the # is located underneath. This weekend when my husband lifts it out of the island top I'll try to locate the # and get back with you. Youve been very helpful thus far. Thank you, Jeri
  • 205 Answers
Hello- I would stop using that burner immediately, it is possible that there is an electrical short either in the burner or the burner switch. This could potentially cause fire or a shock. You will need to have a Tech out to diagnose the problem. Good luck, best regards.
Posted on Sep 28, 2010
  • bopbirds Sep 28, 2010
    My husbands pretty handy. Do you think he could fix it with a new part,,,but which part could it be?
  • dustymirror Sep 29, 2010
    Hello- He could try to fix it. Make SURE that the breaker is off to the unit before attempting any repair. Glass top units are usually difficult to work on because the glass has to be removed and even though the glass is tempered it can still shatter. It is really difficult to say exactly which part it would be. I would look closely at ALL the wiring involving that burner, the burner itself and the switch that controls it. If you could reply with the exact Model number I may be able to locate a parts breakdown to send you a link to. Best regards.
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
I have recently cracked the glass stove top, if I continue to use it will I sustain more damage and how much will it cost to replace it? We have a Bosch 30x24 glass smooth top with four burners electric....
hi gud day,much better to replae the new one compare to buy the glass top only coz the price of the glass is expensive or little diif for the new one.or if the broken glass is not appected to other burner its ok to use the other burner untill to u want to use.tnx
Feb 01, 2009 | Cooktops
Crack on glass top
usually not, I have heard of them cracking with extreme temp changes. like burner on high, some one puts a frozen turkey down not knowing and crack
Jan 26, 2009 | Jenn-Air JED8430 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Crack on glass top stove
Hello
Welcome to Fixya
My name is Huum,
You can replace the smooth top !.
But I will tell you not to spend more than half the price of a new stove. How old is the stove and what's the model number!
Waiting your response.
Please remember to leave a rating before you leave
Dec 11, 2008 | Jenn-Air JED8430 Electric Cooktop
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Cooktops Logo
193 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
