Question about RCA 20F420T 20" TV
I have a RCA 20' truflat model# 20F420T that turns off & on on it's own. what should I do short of shooting it?
johnnydiode
  • 647 Answers
SOURCE: need a instructions manuals for RCA 20in 20f420t
Look for Product Manualswww.Product-Manuals.best-price.com
Posted on Oct 14, 2009
rulds2008
  • 3866 Answers
SOURCE: My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
Posted on Oct 24, 2009
  • 72 Answers
SOURCE: my RCA TruFlat Model No. 20F420T shuts off at
HI,,
ITS NOT PROBLEM WITH TV TIMER...
ITS PRBLEM WITH TV AC TRANSFORMER WHICH IS INSIDE,,
ONE OF THE POSITIVE COIL INSIDE TRANSFORMER ITS SHORTING,,
APPROACH TV TECHNICIAN...
Posted on Nov 11, 2009
MNfisherman
  • 11896 Answers
SOURCE: 20f420t wont turn on, rca tv
power supply aka high-voltage transformer is bad.
Posted on Mar 23, 2010
SOURCE: My RCA TV model 20F420T keeps turning itself on
just remove all the tact switches on the front of the tv and use the remote control all the time.
Posted on Sep 14, 2010
Remove fpa parental lock
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Sep 13, 2014 | RCA Televison & Video
20FP420T FP lock on and can't select input no remote?
Do you mean the 20F420T? RCA doesn't have a 20FP420T as far as I can tell.
Unfortunately, you can't turn off the Front Panel (child lock) without a remote. All of the front panel Power button to turn off the set but not to turn it on. You need a remote that matches the Menu function. Press Menu, then use the Ch+/Ch- buttons to select Preferences. Press OK then press Ch+/Ch- to highlight FPA lock. Use the Vol+/Vol- buttons to toggle the lock function on or off. (Off lets the front panel work normally) Then press Menu repeatedly to exit the menus. A substitute remote can be obtained here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=20F420T&uuid=12994577706920 . This is guaranteed to work with the 20F420T . Most universal remotes should also work as long as they were programmed after 2006.
The manual for the 20F420T is available here: http://support.ttetech.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads.html&NRNODEGUID={35D79B02-4AAE-4834-BFD0-1124EA501FA2}&NRCACHEHINT=NoModifyGuest . Fill in the drop down menus for 20" and the model.
I hope this helps.
Mar 07, 2011 | RCA 20F420T 20" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
Mar 23, 2010 | RCA 20F420T 20" TV
My RCA TruFlat Model No. 20F420T shuts off at will. All the timers are set to off, any ideas?
HI,,
Nov 11, 2009 | RCA 20F420T 20" TV
20" TruFlat cuts on and off on it's on
Hi
This is power supply issue! a defective parts need to replace. like power oscillation. here in the philippines the cost is about 750.00 php.
Thanks!
Dec 29, 2008 | RCA 20F420T 20" TV
RCA TruFlat TV
Be happy to explain how I fixed the problem.......please send $40.00 and I will forward the solution!!!!
Mar 03, 2008 | RCA Televison & Video
Green Screen Then Shut Off
No hay mas solucion que llevarla a un taller para que te la reparen ya que tiene daño en el socket del cinescopio.
Dec 16, 2007 | RCA 20F420T 20" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
515 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
