Question about Toshiba 32A43 32" TV
32a43 tact switch replacement
How do i acces front control panel
The replacement of the tact switches appears to be to technical for me. I will have an
experienced technician repair it.
Thank You
Posted on May 26, 2008
The remote needs to turn on tv
If your'e meaning the set turns on with the remote and works but will not turn on by the power button on the TV itself. Then it would be an issue with the front controls pcb possibly bad tact switches, connections or other issues. But the front control board will require replacement if your symptoms as I described above. If so you can get the front control boards from www.tvcircuitboards.com
Jan 01, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
RCA P52921 changed channels by itself and unplugged it to reset it and
Take batteries off the remote and check if it is the remote , otherwise it is a stuck key on the tv or the control board is gone,
regaards
Mar 31, 2008 | RCA P52921 52" Rear Projection Television
Toshiba 32A43 - suddenly stopped responding to both my Toshiba CT-90157 remote and Verizon FIOS Philips RC 1445301 remote. Replaced batteries in both remotes & tried to reprogram the Verizon remote...
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Sep 28, 2010 | Toshiba 32A43 32" TV
I have no control over the channel selection; the channel keeps changing and I'm powerless to stop it. The issue is not with the remote; the same thing happens if I attempt to tune to a channel manually on...
The problem is likely with your front panel control buttons - the CH up button (tact switch) is stuck on (shorted or changed value). In order to temporarily correct the problem remove the Ch up switch that is located on the front panel control board - it would have to be unsoldered- and then when one is available replace the "tact" switch.
Sep 27, 2009 | GE 31GT740 31" TV
RCA TV
Hi
the tact switch!? that is the swhitsh in front panel of the TV. like the volume button, channel button. that is the tact switch.
Thanks!
Sep 19, 2008 | Televison & Video
Menu pop ups
dopy, the problem is leaky tact switches on the control board, have changed out many of these especially on the 2003 model which of course is the 32A43, part number for the switches is 23344443, swap them and your done, BMW Rider
Sep 06, 2007 | Toshiba 32A43 32" TV
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Demo wont go off
change out all the tact switches on the front control board and you`ll be good as new, common problem, BMW Rider
Aug 15, 2007 | Toshiba 32A43 32" TV
Volume go up to MAX, power button does not work
To all of you, change the tact switches (all of them) on the front panel control board and end of problem, very common problem, part number for these switches is 23344443, any or several will become "leaky" and give all sorts of symptoms, MANY times this is caused by using windex or similiar type cleaners, it gets into the switches and corrupts them, this will fix-ya, BMW Rider
Hi, heres your fix, very common problem usually caused (but not always) by using windex to clean the screen, replace the front control boards tact switches, replace all of them, part number is 23344443, end of problem :) BMW Rider
Jul 02, 2007 | Toshiba 32A43 32" TV
Toshiba 32A43 32" TV Logo
397 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
