Question about Metra Chevy Truck 88 94
Broke, no money! already changed switch still wont switch-off &somtimes switches itself on
After changing oil sending switch is there anything special to do
Try disconnecting negative battery cable for 10 minutes and see if it resets itself.
Oct 06, 2015 | 1999 GMC Jimmy
How do i find the staring modulo on 2001 XL7
what are the starting symptoms , have you had the OBD codes read as will pinpoint the sensor /switch at fault save time and money changing components blind
May 14, 2014 | 2001 Suzuki Xl 7
Somtimes my truck wont start when i push in the cluch
maybe the neautral safety switch is going bad or you dont have a good connection there
Mar 28, 2014 | 1992 Ford F150 SuperCab
Scion xa driverside door switch wont unlock 2006
That's in all prob the switch itself. If you can, open the switch panel & test if you have power & ground w/ a test lt as U move the switch back & forth, if OK, U need a switch. if no power or a bad ground-electrical short. sounds like a switch or the connection. Good luck Frank M (if elec short & U cant handle it, take it in.
Mar 15, 2013 | 2006 Scion xA
What's your problem?gear shifter wont come out of park
Must be the release mechanism tied to the brake pedal is loose or bad. don-ohio
Oct 30, 2011 | 1993 Mercury Grand Marquis
BLACK AND DECKER HANDI SAW ISNT WORKING
there are several trouble shooting you can perform:
1. Check the plug particularly teh wire attached on it.almost all of the wires of a power tools got damage on the wires itself due to a continous moving when working.
2. Somtimes there is a built-in fuse or breaker.
3. Check the Switch.sometimes the spring materials of a switch is malfuncioning and it couldn't connect the conductor to run a power.
4. Check your carbon Brush.You must replace it if it is already below 1/4 inch long.
5.Can you feel a little vibration when you switch the unit?if that so,check the bearing because it is surely the bearing has damaged because the armature and core of the motor is already touching each other thats why it will not rotate anymore..
Oct 30, 2009 | Black & Decker Cordless Handi Saw
From time to time my menu will come up and then the remote wont work the buttons on the front are all backwards but if i pull the speaker cover off to get to the back of the buttons and wiggle the 5 wires...
My bet is that the MENU switch has become leaky. That's why the menu keeps coming up on it's own. If any of the front buttons are held down the remote won't work. A leaky switch is the same thing. That menu switch needs to be replaced. A real solid repair would be to change all the switches on that control panel.
Jun 02, 2009 | Televison & Video
Faulty Cruise Control
my cruise control and the controls on the steering wheel are not working, Just picked up my 2005 BMW Z4 from the dealer. Where do I start Looking to solve the problem.
Nov 21, 2008 | 2005 BMW Z4
Metra Chevy Truck 88 94  Logo
62 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
