Question about Panasonic NN-H275 Microwave Oven
Heating ceases after 2 to 3 seconds. I tried to take out the main plug thinking it would restart the machine, The machine worked for some time then again started to cease after 2 seconds. This has been happening for the past 5 months but there are times that it really worked inconsistently so we didn't bother to call for help yet. But this time is really worse. Please tell me what to do. Thank you in advance.
    Top Expert:
  • Panasonic Master
  • 34,153 Answers
The problem could be intermittent failure of the magnetron ot possibly faulty wiring of the door interlock.
Posted on Jul 27, 2017
3 Suggested Answers
  • 518 Answers
SOURCE: microwave heated food an hour
A make and model would have been nice, but try unplugging it from the wall outlet for 15 minutes.
Hope that helps...
Geno
Posted on Mar 26, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Posted on May 31, 2010
Testimonial: "Thanks for the good response ... and warnings! Looks like we are shopping for a new microwave."
Microwave starts humming when connecting to mains
Chances are a door switch or power / cooking relay is shorted.
Jan 08, 2013 | DeLonghi Microwave Ovens
MICROWAVE WILL RUN FOR LESS THAN 10 SECONDS AND THEN DOES A COMPLETE SHUT DOWN REQUIRING ME TO REST TIME AND DATE TO TRY AGAIN
I would say that when the microwave is switched on to cook, the magnetron heaters take about 3 seconds to get the magnetron to draw current and that would coinside with a poor connection in the mains power plug or fuse holder in the machine.
Seems logical to me.
Jan 01, 2011 | GE JVM1650 1000 Watts Microwave Oven
Timer runs super fast, I dont think its heating at all. set for one hour, takes only a few seconds to run. Owned since 2003
I have a Maytag that did the same thing. I unplugged it for about 2 minutes, plugged it back in and it is working fine.
Nov 30, 2010 | Kenmore 62342 Microwave Oven
Heating ceases after one second
May 30, 2010 | Panasonic NN-H275 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Kenmore Microwave Displays Error Code Reading "Prob"
I would bet that the temperature probe socket has some accumulated grease, etc. in it which may be changing the resistance of the contacts, making the control board think the probe is installed but defective.
First, please unplug the oven before you investigate.
The best idea is to clean the probe socket contacts.
You'd need to remove the outer cover, and the probe socket should be located on the right side of the chassis.
If you can cut thin strips of fine sandpaper and work them back and forth between the contacts, that's the best way.
You can plug & unplug the probe while observing the socket to see how the contacts work.
Your socket may be sealed, and that would possibly require you to carefully take it apart. That's a bit of a gamble, as it may crack due to age.
Another idea is to take a wad of paper toweling, hold it with your right hand over the back of the probe socket, and spray contact cleaner or WD40, etc. into the opening of the probe jack from inside the oven cavity with your left hand.
Then plug & unplug the probe several times, wipe any spills and try the oven again.
If the probe unplugs form the control board, you could disconnect it and try the oven.
Let me know how it goes.
Aug 02, 2008 | Microwave Ovens
Not heating properly
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't do it, and your line voltage is right, then I would say your magnetron is dying.
Slow is heat is a typical symptom of magnetron failure.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 21, 2008 | LG LMV2055ST Microwave Oven
Microwave heated food an hour ago but has stopped heating it now. Sensor cooking ceases and displays "F3H". Fan has stopped working also.
Hope that helps...
Geno
Mar 26, 2008 | Microwave Ovens
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-H275 Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
