Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The temperature is to warm in refrigerator with the setting on high,I did on plug and try to clean,first.
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 28, 2010
The temperature is going high and is runing all the time
Hi mh_petrovici - When doors are opened too often or too long, warm air enters the refrigerator causing it to run more or when the room or outside temperature is hot, it is normal for the refrigerator to work longer under conditions. Temperature control may be set too cold (normally found in refrigerator section), set control to warmer setting until refrigerator temperature is satisfactory. Allow 24 hours for temperature to stabilize completely. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Check and see if the condenser is dirty. A dirty condenser blocks air that dissipates the heat that the condenser removes from the unit. Clean the condenser every 6 months and more if you have animals in the house.
Nov 23, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
High temp ligh is on, Amana SRD23V side by side fridge
Check compressor is running (humming sound) and condenser warm but not hot.Check temperature setting. If all good, call out a technician
May 18, 2012 | Amana Refrigerators
Hello. Our whirlpool fridge is too warm now, but no matter how we adjust the temp control from low to high, it still warm like room temperature. It happened suddenly the day before yesterday. Can you tell...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Whirlpool Refrigerators
Freezer not cold enough to maintain ice and food
  • When your refrigerator isn't cooling your food and drink items, first check that the power cord is plugged into a working electrical outlet. If you recently plugged in the refrigerator for the first time, it will take approximately 8 to 12 hours before the refrigerator is cool. Even though the refrigerator is cool in this time frame, you shouldn't place the refrigerator to a colder setting until the initial cool down stage, which takes 24 hours.
    If the refrigerator has been running for 24 hours, you can adjust the refrigerator to a lower setting. The control panel is located in upper portion of the refrigerator compartment. Press the up arrow button to set the refrigerator to a higher setting, which will decrease the temperature of the refrigerator compartment.
  • Door
  • If the temperature control is correctly set but the refrigerator compartment still does not cool down, check the refrigerator door. First, remove any food or drink items that are preventing the door from fully closing. In addition, make sure all of the drawers are fully closed, as they may keep the door from closing.
    Next, clean off the gasket with warm, soapy water and a sponge. Rinse the soapy water off of the gasket. If the gasket is not clean, it will not create a seal with the refrigerator.
    Another reason the refrigerator is not cooling down may be because the refrigerator door is opened too frequently or left open for a long period of time. Pay attention to your use of the door and try to shorten the amount of time the door is opened.
  • Other Causes
  • Your Jenn-Air refrigerator might not cool down for other reasons. If you have recently added food to the refrigerator, the temperature of the food may have an effect on the temperature of the refrigerator. The temperature in the refrigerator will adjust after the food sits in the unit for an hour or more.
    You may have obstructed the air flow on the inside of the refrigerator with the placement of your food. The rear air grille is located under the crisper drawers. Move any food items away from the rear air grille to increase the air flow through the refrigerator.
  • If those thing above did not solve your problem you better check and replace the relay and compressor and it will be good as new. Thanks
  • Jan 23, 2011 | Jenn-Air JCD2389G Side by Side...
    Suddenly showing "HI" in room temp window. Cold then warm air blows out.
    "Hi" means your compressor has gone off on a high temperature limit. Basically, your outdoor coil is dirty and needs to be cleaned or your outdoor fan has stopped working. An air conditioner works off a simple principle of removing heat using a low temperature and low pressure refrigerant. Your compressor does what it is called. It changes that low temperature, low pressure refrigerant into a high temperature and high pressure refrigerant. Your outdoor fan blows over that high pressure gas and it blows out hot air. First thing to check is to turn your unit on, and go outside and feel if you have any air blowing out the back. If you don't, you have a bad fan. If you do, you need to clean your coil. Spray some simple green on your outdoor coil and let it sit for about 15 minutes. Then grab a hose and under low water pressure, wash out your coil from top to bottom pointing the hose in a downward direction. You do not want to point the hose straight into the unit. Make sure you disconnect the power and allow it a couple hours to dry before you plug it back in. If it's just a dirty coil, you should be good to go after that!!
    Sep 28, 2010 | Maytag Portable Air Conditioner M6P09S2B
    Quit cooling. the condensor is warm to the touch but is still running and cutting off and only runs for about 20 sec.
    Sounds that the refrigerator can nit analyse the actual temperature inside it. It reads a high temperature as a lower one and thinks its sufficient. If you get its internal settings rectified, it will work fine.
    Apr 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    My Samsung Refrigerator can not keep the set temperature.
    Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
    Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
    The refrigerator is warm
    could be your compressor going out. how old is the fridge.make sure that was water and not freon check your coils unde the fridge see if there really warm. and most people don't clean these out so the icebox has to work harder.
    Apr 14, 2010 | Whirlpool ET8MHEXR Top-Mount Refrigerator...
    Frozen food in fridge
    Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
    Mar 29, 2009 | Frigidaire FRT18G4A Top Freezer...
    Temperature of Refrig and Freezer too warm
    Sounds like your fridge may be short of refrigerant.
    Mar 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
    29 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
