Question about HP OfficeJet Pro 1150c All-In-One InkJet Printer
Scanner lamp failing on HP Officejet 1150C printer
SOURCE: Scanner Failure
I had the same problem along with the problem of "remove and check color cartridge." Nothing worked until I completely disconnected the power to the K80, both from the wall and from the K80, and left it disconnected overnight. In the morning all worked great. The problem was gone.
John
Posted on May 23, 2008
  • 35 Answers
SOURCE: printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Aug 01, 2008
Teis
  • 340 Answers
SOURCE: HP officejet 4355 all in one print fax scan copier to connect wit
Hi there, and welcome to FixYa,
You will find your driver at this site: - choose your operating system, download and install, plz let me know the result.
/Teis 6ef1705.png
Posted on Dec 29, 2008
SOURCE: HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
  • 100 Answers
SOURCE: hp officejet 4315V scanner will not install with windows vista
Try to scan from paint.....
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Posted on Mar 15, 2010
Print result in black and white appeared with lines
Most inkjet printer problems result from clogged or empty cartriges. Try inkjet cleaning program on printer, then run test. If that doesn't solve problem, May need to replace cartridge(s).
But the way, HP requires replacement with new HP cartridges. Has software that can tell.
Apr 25, 2016 | HP OfficeJet Pro 1150c All-In-One InkJet...
Installation hp officejet pro 1150C sans CD d'installation
Click here
Click on above link select os and download driver and install.
Let me know if you need further assistance.
Thanks for using FixYa.
Oct 03, 2011 | HP OfficeJet Pro 1150c All-In-One InkJet...
Officejet G95 scaner falier
Hi its normal one of two things 1 the scanner unit is being stopped or snagged as it travels
to test this lift the lid switch on an look to see if it is obstructed.
2 the lamp in the scanner unit is not putting out enough light, the machine monitors the light out put and if insufficient it gives a scanner error.
I'm sorry to say the the cost of a scanner unit normal puts the machine beyond economic repair
But google hp partsurfer this will get you parts
good luck Ian
Mar 25, 2011 | HP OfficeJet G95 InkJet Printer
Keeps telling me to "Remove and check black cartridge" I take it out but cannot see anything wrong with it and it still prints perfectly. Any ideas as to what is causing it.
The black ink cartridge may have damage or faulty.
Also the cartridge may not be original or genuine, causing the printer to read it as damaged.
also possible is the sensors on the cartridge port is dirty or have accumulated dust, try cleaning them too.
Jul 02, 2010 | HP OfficeJet Pro 1150c All-In-One InkJet...
I keep getting a scanner failure when I try to fax something from my all in one Officejet k60.
i can understand the situation here is the soluition for you :
1.TRY TO MAKE A COPY
2.if the copy does not happen open the scanner glass and check whether the scanner lamp that is tdo you see any light in the glass glowing or moving
3.if nothing gloes or move then i am sorry to say that you will only be able to print from the printer and nothing else
4.if the printer is in warranty call hp they replace it for you .............................. thank you and hope you do see the scanner lamp
Oct 20, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
My HP 7110 Officejet says ''scanner failure.'' It will not let me fax or copy. How do I fix this?
If you can remove the glass, you need to clean the lamp and mirrors in the scan assembly, this error happens after the lamp ages and dust gathers on the scan mirrors. It's very expensive if you can even find a new scan assembly.
Jun 30, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 5610xi All-in-One displays carriage jam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab92
Jun 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Printe driver for HP1150C Vista
I just checked HP's ASP support site and infact they have not written drivers for that printer. If the drivers did not auto install when pluggin in, unfortunatly nothing will make it work.
Jun 04, 2008 | Microsoft Windows Vista Ultimate Edition
HP OfficeJet Pro 1150c All-In-One InkJet Printer Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
