Question about DeLonghi CF210 Portable Air Conditioner
Air Conditioner will not start and has a flashing red light on top
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Furnace comes on but wont stay running,when it shuts off a red light flashes
What light is flashing Red? Is it on your thermostat or is it a red light inside the package unit at a circuit board?
Oct 08, 2013 | Intertherm P3RA-048K Air Conditioner
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
The blue light keeps blinking and error e04 comes up
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
Jun 21, 2010 | Danby Portable Air Conditioner
Red light on dash for air conditioner flashers and turn of air conditioner light keeps flashing toyota camry altise 2002
never seen a red light on a dash for a air conditioner before,are you sure its not for the air bag?
Oct 18, 2009 | 2002 Toyota Camry
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Jul 16, 2009 | Danby DPAC120061 Portable Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
124 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
