Question about Whirlpool Duet GHW9150P Front Load Washer
What does code F -21 mean - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Posted on Sep 28, 2010
What does the thermador dishwasher dwhd640jfp error code e:21 mean?
E21 Circulating pump blocked.
A blockage between the motor or the pump resulting in insufficient water flow.
Feb 22, 2015 | Thermador Dishwashers
What does Toshiba DVD error code E 21 mean?
It seems to suggest that you are using unsupported media to record on.
Feb 10, 2015 | Toshiba Televison & Video
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
Oct 06, 2014 | Washing Machines
I have a 1997 Dodge Stratus with Check engine codes as follows: Key ON,OFF,ON,OFF,ON codes 12, 34, 21, 55 I understand 12 is recent disconnected battery & 55 is end of test, but can't find definition of...
Jeff: Go to "Allpar dot com" website and look for a complete list of codes for the older Chryslers. From mine I remember code 34 as having at least two posible meanings: a) EGR Solenoid circuit problema, and b) Speed control problema. Code 21 means a problema in the Oxygen sensor. Amclaussen.
Aug 23, 2013 | 1997 Dodge Stratus
95 dodge caravan se code 12 21 55
Well, the code 12 is telling you the battery or the computer has been disconnected in the last 50 starts, code 21 is a problem with the O2 sensor, and code 55 is telling you there are no more trouble codes stored in memory.
Code 21 means the O2 sensor is not switching from rich to lean, which can be a faulty sensor or a fuel problem.
Aug 28, 2012 | Dodge Caravan Cars & Trucks
What do fault codes 12, 21, and 55 mean on a 1996 dodge caravan?
Code 12 = unplug battery recently (allways appear this code)
Code 21 = O2 sensor (the way to solve is replace it)
Code 55 = finish test
Good luck (remember comment and rated this post).
Apr 21, 2010 | 1996 Dodge Caravan
Checkengine codes 12 21 55
how do I replace an o2 sensor in a 1997 Jeep Cherokee ?
Mar 19, 2010 | 1997 Jeep Cherokee
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Code error for O2 sensor?
Code 21 the check engine light will flash 21 times cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
Aug 29, 2009 | 1995 Dodge Neon
Engine diagnostic codes
I don't have a dodge ram but the codes for the dodge vehicles where pretty much the same. For my intrepid the codes read for the following numbers
12 - Problem with battery connection (This usually happens if you disconnect the battery)
21 - Problem with the oxygen sensor circuit
52 - Oxygen Sensor signal input indicates rich mixture during engine operation.
It sounds like you may need to change an oxygen sensor. Hope this helps.
Aug 15, 2008 | 1995 Dodge Intrepid
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
