Question about HP DeskJet 5150 InkJet Printer
It doesn't print
I installed the printer and the drivers,but it doesn't print. It prints only if i push the ''arrow'' button and it prints the label of hp. it doesn't print my documents i want to be printed. what should i do?
    Master:
  • 638 Answers
  1. HP LBEL THAT PRINTS WITH THAT ARROW BUTTON IS HP PRINTER SELF TEST WHICH SHOWS UR PRINTER IS OKAY--,THE PROBLEM IS COMMUNICATION BETWEEN UR PC N PRINTER.
  2. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  3. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  4. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  5. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  6. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  7. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  8. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE.
Posted on Jun 03, 2008
Moving an HP 3005p dn printer from our accounting department (which was networked) to my desk to print directly from my pc to the printer. Will it work? I am on Windows XP and Office 2007
Yes this will work as long as the printer has a USB port on it and you have the correct drivers for the printer installed on your machine.
You may need to factory reset the printer depending on how it was set up networked.
a NVRAM initialisation resets everything in a cold reset plus serial number, page counts and EIO cards - use with caution.
0. print-off a selftest/configuration page first to reset things if necessary.
1. remove all installed accessories.
2. power off printer
3. power on printer. When the memory count begins, press and hold the "down arrow button - keep holding the "down arrow" button until all three control panel lights flash once then remain on (can take upto 10 secs)
4. Press the "Up arrow" button.
5. Press the Menu button - the display should show SKIP DISK LOAD
6. press the "UP arrow" button until NVRAM INIT is highlighted
7. Press the "tick" button - the printer continues its power-on sequence.
Hope this helps
May 04, 2011 | HP LaserJet P3005 Printer
Having problems with printer margins. It will print the first label correctly then the next 4 or 5 it will mess up the margins and print out on two labels
You Have to set label size in the printers driver. A hundred diferent label sizes can be used but the driver must know the size to layout the bitmap correctly
Goto printers and faxes then right click on your zebra printer driver. Left click properties and then left click the advanced tab, then left click printing defaults button. In the zebra designer driver size is on this page. The Zebra Universal driver you click a few levels deeper by clicking paper output then paper size. If your size is not listed in the drop down arrow then click customize, then highlight user defigned on the upper left off the screen and enter your correct label size.
May 09, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Only prints in black. Windows 7 driver update
Print a 'Configuration Page' from the printers <Information Menu>
Press the green tick button to enter the menus, and use the <, > arrows to scroll thru menus.
Then press the green tick button to select...
If, as I suspect, your Configuration Page is in colour, and looking ok - the the problem is in your computer - Printer Driver setup, or Windows......
Like all the others
Have fun.
Dec 21, 2009 | HP LaserJet 2605DTN Color Printer
IT PRINT A LABEL THEN SKIPS A LABEL THEN PRINTS A LABEL
You need to make sure the media and ribbon are installed correctly, and then make sure the printer is calibrated. Once you verify the media is correct, power off the printer and then back on. It should feed a few labels. Then press the button to feed again to make sure it feeds only one. If it does, then the printer is set. Now, when you go to print, if it still acts up, you need to check either the driver settings or the software settings. Label size could be set incorrectly.
Aug 30, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Just installed the 4200 pcl 6 drivers. On server
Press the green buttton, arrow down to Paper Handling, arrow down to tray 2 size and tray 2 type and verify they are set to "letter" and "plain".
Jun 24, 2009 | HP LaserJet 4200 Printer
HP 4300n prints off the right margin
You possiblely have a font set wrong in your printer. Push the green check button, arrow down to printing, push the check button again, arrow down to PCL and push the green check button again. Arrow down to Font Source, push check button again and check setting, should be internal. Push the left arrow button till you get back to Font Source and down arrow key to Font Number, all ours are set to 3. Left arrow key back to Font Number and down arrow again to Font Point Size, all of ours are set to 12.00. To get back to ready, uset the left arrow key.
If this is all correct, then it has to be in your software.
Mar 05, 2009 | HP LaserJet 4300n Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Tlp 2844 printing issues
try powering off the printer, pressing the green button while powering back up then when u see it blink let go of the green button
May 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
HP DeskJet 5150 InkJet Printer Logo
64 people viewed this question
Ben Johnson
