Question about Sony Playstation 3 (PS3) Console
Flashing red light [happens when switching console on,cuts out]
  • 4,102 Answers
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
a8
Posted on Sep 28, 2010
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
PS3 wont work, red flashing light
If it flashes yellow to you have the Yellow light of death. google it. otherwise its just overheated
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 cut out and wont turn back on
my ps3 cut out whilst playing it now won't switch on
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
My red light is just flashing and the PS3 will not switch on!
this is known as the yellow light of death or ylod...this is happening alot lately....sony charges 150$ to fix this....if you have any electronics skills you will find a solution on youtube....just google or youtube yellow light of death solutions..sorry it happen to me twice..
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
Red light flashes sometimes and not reading disks
Hi carla 0166,
Its not good news im afraid, that red light that flashes on the console is also known as the "ring of death".if one segment is red its not too bad but if its any more it wont work.
To get around this as daft as it sounds you need to overheat the xbox 360.
i know this as it has happened to me also.
simply switch the x box 360 on and then wrap a towel around it and leave for 30mins.
this will overheat the console and when switched back the red light should be gone.
I hope this has helped :)
Sep 18, 2009 | Sega The Club - Xbox360 for XBox 360
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
Brand new PS3 has red flashing light
if its a flashing red light it needs looking at,maybe the fan or the heat sync is faulty.If it is new take it back to where you got it from and get a replacement,DONT OPEN IT.good luck.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
