It is saying something about framework 2.0 and just is not working can a downlaod i again?
Updating .net framework
The Microsoft .NET framework, sometimes called dotnet, is a collection of software libraries and assemblies installed on the Windows operating system.
Software languages that are .NET compatible will take programmer code and construct it into a language, called bytecode, which the .NET framework is able to load and utilize.
You will need to update your .NET framework if the application you want to use was built with a more recent edition.
Open your web browser and visit the .NET framework downloads page on the Microsoft website (See "Below").
http://msdn.microsoft.com/en-us/netframework/aa569263.aspx
Click "Install It Now" and click "Download" to obtain the framework installer.
Save the file to your desktop, then double-click it to open the installation.
Review the software license at the top of the page, then place a check mark next to "I Have Read and Accept the License Terms." Click "Install" to proceed.
Click "Finish" when the "Installation Is Complete" window appears.
You have now updated the .NET framework.
Jul 13, 2013 | Iolo Technologies System Mechanic: Windows
Reinstalling PrintShop 20 after 'computer failure'. Error installing Microsoft(R)NET. Framework. This is happening when installing PrintMaster & Creating Keepsakes Scrapbook, as well - all...
Hi
There are two things I need to know before I can solve the problem.
1. what windows is installed on the computer? Is it windows 2000, windows xp, windows vista, windows 7 or something else?
2. do you know if the windows is 64bit version? If you don't know, do you know how much RAM memory does the computer have? less than 4GB? more than 4GB?
To find out which version it is 32 or 64 hold down the windows key and press r, in the run menu that comes up write msinfo32 and click OK
Now on the system information page that opens, on the right of the window find system type
Tell me what it says there if you don't know if the computer has 64bit or 32bit windows installed.
Dec 07, 2010 | Broderbund Computers & Internet
When im installing the game .. it says that Setup was unable to install Microsoft .NET Framework 1.1? .. can you help me how to solve this problem .. so that i can play the game NBA 2k10 .. please......
Download .net framework offline from the link below and try to install it first and then try to install the game.
To download .net framework 1.1
http://www.microsoft.com/downloads/details.aspx?FamilyId=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en
In case if the game or .net framework doesnt install properly then use the .net cleanup utility and clean all the installed .net framework versions.
Download the .net cleanup utility from the link below:
http://www.softpedia.com/progDownload/NET-Framework-Cleanup-Tool-Download-116561.html
Click on
Softpedia Secure Download (US) [ZIP]
to download the file.
once all the cleanup is done try installing the game again.
Rashish.
Aug 16, 2010 | Computers & Internet
FixYa Expert Utility - .Net Framework unhandled exception
try to uninstall the latest update of the .Net framework and then download and install again.
in most cases it will solve the problem
Apr 04, 2010 | FixYa Service
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Empowering technology framework incompatible with vista ultimate
downlaod all Empowering tech software from Acer direct for ur notebook
see link pls rate FIXYA fo rhelp
ftp://ftp.support.acer-euro.com/notebook/aspire_5315/vista/Applications/
Apr 18, 2009 | Acer Aspire 5315 Notebook
Problem installing lifecam 2.04
just had the same problem read in another forum that you have to uninstall the net framework 2.0. (see below) which I found to complicated ...I just plugged the camera in - and at least with Skype it works ....
I found this link helpful:
http://support.microsoft.com/kb/923100/en-us
Try and use method one to uninstall your .net framework software. Method one
did not work for me, I kept getting issues with removing both 2.0 and 3.0.
I then used method 2 which entails following another link and downloading a
.net framework cleanup tool. I ran the program to cleanup ALL .Net versions.
Then I went back to Microsoft Downloads and downloaded .net framework 1.1,
2.0 and 3.5 (not 3.0 - for some reason 3.0 would not download and created
issues).
Once these .Net Framework downloads were installed I downloaded and
installed LifeCam 2.04 software and my kid was up and running in 10 minutes.
It took me over a week to get this issue resolved.
One more thing, when you are downloading and installing your .net framework
files you need to make sure you download in the proper sequence. Also, for
some reason I encountered printer issues the first time through this. The
second time I just unplugged my printer untill all downloads were installed
and I did a computer restart and the printer issue went away.
Feb 11, 2009 | Microsoft LifeCam VX-6000 Webcam
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
Jan 16, 2009 | Office Equipment & Supplies
You cannot install the Microsoft .NET Framework 1.1 because the NET Framework 2 is already installed. The NET Framework 2 is the latest version of Microsoft NET Framework. I think you can remove the latest Framework in the Add/Remove Programs from the Control Panel. Then restart your computer and install the old version. But my advice is, just let the latest NET Framework remain and don't uninstall it.
Jun 02, 2008 | Computers & Internet
NET Framework and msvcr80.dll programs
The msvcr80.dll is required for the software developed under microsoft C++. And if the microsoft visual C++ is not installed on that machine this raise error.
It sounds you are facing same problem, if then downlaod microsoft visual C++ redistributable package and install it on your machine. I think it will fix your problem.
Click here to download
Thanks
Iqbal
Mar 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
