Question about Kenmore Dryers
My dryer just stopped working, i checked the breaker box...nothing ...any suggestions ??? thanks beverly
  • bev7795 Sep 28, 2010
    thanks so much,i will check on that....
    last question, i hope...what is the way of getting the top off of the dryer to get to the door switch?????? thanks
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 28, 2010
  • 1 more comment
    thanks for your help, but i think itis the door switch that is bent, howdoi fixit ??? thanks
  • D. Floyd Kolb
    D. Floyd Kolb Sep 28, 2010
    Sometimes you can bend it back enough for it to work but that is just a temporary fix it will bend again...
    You should look for a replacement and install a new one for a permenent fix...
    Here is a tip that will help you with the online buying...
    How to Buy Appliance Parts Online
    heatman101
  • D. Floyd Kolb
    http://www.fixya.com/support/r3907570-bu...
Dryer just stopped coming on. You hit the on button and nothing happens
You do not mention if you have checked the plug wiring , maybe it has a loose connection ?
Nov 24, 2014 | Kenmore Dryers
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
Stop running? No apparent fusses blown.. Just had belt replaced
check your breakers. in the main panel box
if nothing works still , its a bad control board on the dryer
Jul 31, 2010 | Maytag PYE3200 Dryer
Dryer was working the just stopped and won't start back
check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Sep 13, 2009 | Amana NED5400TQ Electric Dryer
Dryer has just stopped working, no power what so ever.
Check the timer switch. All the power goes through that switch and they do fail over time. If that isn't the source of the problem, then check the door switch. When they fail, just like a top-load washer door switch, NOTHING will work because it senses the door is open even when it's closed. Those are two most obvious things and the easiest to check.
Hope that helps!
Jan 09, 2009 | Frigidaire GLER642A Electric Dryer
Washer
THE DRYER WORKS OFF 220VOLTS,THE WASHER IS 110 VOLTS,CHECK WASHER PLUG BY PLUGGING IN A RADIO TO SEE IF YOU HAVE POWER,CHECK BREAKER BOX ALSO,MAKE SURE WATER IS ON TO,THANKS-MIKE
May 27, 2008 | Washing Machines
Son Threw in a VERY Wet Baseball Uniform - Dryer Now Not Working
ok check the fuse inside the unit! that is attached in the wire you can see the fuse there! if blown replace a new one! then observe the unit!
Oct 03, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
