I have a ibico PQ12 laminator that won't heat. I used the machine yesterday and it worked fine. This morning it has been on for over 1 hour and won't get hot.
3 Suggested Answers
SOURCE: I have a Ibico el12 ii laminator and need to know
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Posted on Oct 02, 2009
  • 17 Answers
SOURCE: Hi, Our Ibico IL19VT Laminator (A2)
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Posted on Jan 14, 2011
Why won't my laminator turn on?
There is a heating unit inside of a hot laminator. Sometimes when you use this machine for too long it can damage some of the internal components because most of those things are full of plastic. You may want to see if Fellows can take it back under warranty. If they can't you are going to have to get a new one.
Feb 05, 2017 | Fellowes Office Equipment & Supplies
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
User manual for ibico pl-330 ic
http://office.manualsonline.com/support/other/laminator/laminator-manual-required-2292677
Oct 12, 2014 | Office Equipment & Supplies
I have a Ibico el12 ii laminator and need to know how to use it. I cant find the instruction manual for it at my new job i put the sheets in as it shows but it labinates the first 1/2 inch then goes no...
Jul 02, 2009 | Office Equipment & Supplies
A/c compressor
It probably failed because it reached high temperatures or pressures. make sure the regular maintenance has been performed then wait 1 day and try again. It has internal overload protection and that can take hours to reset. If this doesn't work then you probably need a licensed technician to take a look at it.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
172 people viewed this question
jasbo
jasbo
