Question about Navman F20 GPS Receiver
F20 GPS wont detect internal memory
  • robbospoon May 24, 2008
    do u mean the external sd card
    f-series failure
    unable to detect internal memory
  • 3,037 Answers
The memory card is not the thing at fault ginko, this device has its own internal memory apart from the card.
If it is coming up with an error saying unable to access internal memory, this is a known problem and Navman says that some units are defective and you just have to take it back to where you bought it or give the manufacturer a call and they will take care of this for you easily with no problems and you can then get back to using this.
For support call the number that came with your unit or
http://www.navman.com/Navman/Templates/standardcontent____3516.aspx
Posted on May 24, 2008
  • Benjamin Patri
    Benjamin Patri May 24, 2008
    Please let me know if you have any further questions and I would be glad to do what I can, if not, then I hope you have a good day.
    oh yeah, and good luck robbospoon
  • 19,396 Answers
Remove memory and put it back, if it still does not work memory is probably faulty.
  • 1 more comment
  • Ginko
    Ginko May 24, 2008
    To perform correct diagnosys, remove battery, unplug and remove memory card, test memory on a different device (eg a laptop with card reader). Put card back inside Navman, if it still does not work memory card is gone. Check your guaranty terms to see if you can get a replacement.
    Regards
  • Ginko
    Ginko May 24, 2008
    Yep, I was talking about the SD card, what error message do you get exactly?
  • Ginko
    Ginko May 24, 2008
    Yes, that is a problem with SD card, You need to replace SD card, as unfortunately, as far as I know, there is no other way to clear the error. If message does not clear after replacing card, you may also need to restore file system.
    Here is Fixya thread regarding same f20 problem.
Navman f20 wont turn on says F20 ERROR UNABLE TO DETECT INTERNAL MEMORY
Not much to do here I'm afraid. a repair is needed. If your device is not under warranty anymore, you can get in touch with Navman / Mio, they have a trade in offer towards a new Mio device
Feb 22, 2011 | Navman F20 GPS Receiver
Erreur f20
This is a fault with the internal memory chip failing. It can not be fixed and requires the unit to be sent to Navman and the chip replaced.
Return your GPS to the place of purchase and they will complete the return for you if you've had it less than a year. You will need a repair ref number from Navman before sending it back.
This would cost you if the items out of waranty.
PLEASE rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 11, 2009 | Navman F20 GPS Receiver
Error F20 unable to detect internal memory
The internal memory on the F20 is actually an mini SD card inside the unit and this fault is caused if the card can't be read. This is mostly likely because there is a poor connection to the card. To cure the problem:
1) Remove the two screws on the bottom of the unit.
2) Divide the two halves of the case. Its best to do this by using your finger nails or a plastic lever. If you use a screwdriver or something similar you will most likely damage the case. Take care when you finally are able to divide the two halves of the case not to strain the cables connecting the battery and loudspeaker.
3) You should be able to see the SD card in its holder on the circuit board. To remove the SD card pull the top edge away from the board and the top half of the holder should hinge outwards. Don't try to pull the card out as you would do from a normal external SD slot.
4) Examine the terminals for any corrosion or contamination. In most cases just removing and re-inserting the card does the trick. You can safely switch the F20 on with the case still open, but don't attempt to insert or remove the SD card with the F20 turned on as this may damage the circuitry.
5) If this doesn't solve the problem the card itself may be corrupted. You can check this by inserting it in a computer card reader to see if it can be read that way.
Dec 27, 2008 | Navman F20 GPS Receiver
F20 navman error
You need to remove the 2 screews from the bottom and then gentley prize the unit apart from teh bottom using a blunt broad knife will help if you cant have the plastic case splitting tools which are used in the trade,
then once apart the same side where the power button is you will see a microsd card its the same as in a mobile phone just pull it down from the top (its hinged at the bottom) then make sure the card is in correctley and then close it back and test (b4 putting the case back on) that will fix it we ahve a lot of these coming in and its where its been dropped etc and jumps out thats it
from fototime. co .uk
Oct 29, 2008 | Navman F20 GPS Receiver
Navman F10.........Just Out Of Warrantity
hi sir,,
may be memory card correpted..
Sep 01, 2008 | Navman F20 GPS Receiver
Error message on Navman Navman F Series Failure Unable to detect internal memory. Please return the unit to dealer. Can anyone help?
I have a F20 here I am currently tring to fix.
The error comes from the internal memory card being faulty.
It is only a micro SD car.
It may be totally usesless, or need re-programming via the USB port.
You can download the firmware, and it fixes a working MicroSD card.
If your card is damaged, then you will have to replace it, and strip the F20 down to do so.
Then you can upload the firmware.
I warn you, though.
Stripping it down is a bit tricky.
I replaced this F20 memory card, and put on the firmware, but have a new error, that it cant find any maps installed.
Hope this helped you
Michael
Scratchmittens@htomail.com
Jul 14, 2008 | Navman F20 GPS Receiver
Navman f-20
Change bad internal MMC Card for a new one, connect via USB to PC , run f20servicepack1.exe. Don't forget to install Navman's USB drivers ( c:\program files\navman\f20 service pack\USB\ .
May 28, 2008 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Problem
go to the other receiver prob to get clue
May 24, 2008 | Navman F20 GPS Receiver
NAVMAN F20 failure - unable to detect internal memory
I think that the micro SD card inside the GPS is not in the good position, it is necessary to remove the grey sticker on the rear of the GPS and open the hood to access the SD card and then you can plug it in good position.
DAMS
Dec 25, 2007 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
184 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
