Question about Maytag Washing Machines
I have two Maytag washers, LA7400 and LAT333444F Which is the better machine
Maytag mvwc300vw0 washer
What is your brand - maytag? indesit? You really hav to be specific if you want solutions. The better you describe your prob patiently, the better results you will get....................don't forget this is a free service, guys willing to help.
May 26, 2013 | Washing Machines
Maytag performa washer during spin cycle tub is making loud banging noise and continues even when clothes are evenly distributed
This sounds like the transmission is going. Better get another washing machine other than a Performa.
Jan 03, 2010 | Maytag Washing Machines
My maytag washer was makeing noise and we moveved it out and found a black plastic cap that was in two and fluid leak.
The plastic cap goes underneath the washer on the end of the transmission shaft below the belt pulley.
You may have a transmission oil leak causing the noise.
This machine is worth repairing.
It is a better machine than any brand made today.
Nov 12, 2009 | Maytag Dependable Care LAT9416
MAYTAG WASHING MACHINE WILL NOT HOLD WATER. JUST KEEPS RUNNING WATER OUT
You may have a siphoning situation with your washer. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple matter of drain line placement. Please read through the link provided and verify your washer installation. If my diagnosis is not correct, please post back to this thread and elaborate some more on your symptoms, so that I may provide you with better assistance. Hopefully, this solves your problem.
Jun 19, 2009 | Maytag PAV2300 Top Load Washer
How to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Jan 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Dec 29, 2008 | Maytag SAV2655A Top Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
