Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I am not sure what is wrong as this is my first time owning a john deere. is this a selector problem or are these gears cabled to the gear box
    President:
  • 1,627 Answers
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Posted on Sep 29, 2010
  • AK41 Oct 19, 2010
    Remove floor, you should find a broken pin on the 1st to reverse shift lever cable on top of the gearbox,the tractor possibly will not start you can get 2 and 3 as its in gear allready best of luck
My reverse won't work
Donna, there could be an issue in the transaxle/gear box take it into a good small engine repair shop and have them diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
John deere riding mower l120 has no reverse
John Deere SX 85 will not go into reverse or move backwards
Riding Mower Will Not Go In Reverse Quick Fix
Jun 12, 2016 | John Deere Garden
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
197 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
