Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Clothes to wet after spin cycle - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 17,129 Answers
Possible that the program controller is faulty in the spin cycle and so is not outputting to the motor drive. You will need to check the power to the motor is not present check the controller output for loose connections or a failure to give power to motor to spin and dry.
Posted on Sep 28, 2010
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
Clothes wet after rinse cycle
lift the washer on its side and see if it has a drive blet that broken for the spin cycle.
Sep 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
