Question about GE (PSS26MSRSS) Side by Side Refrigerator
Food is freezing, and water line is frozen.
I have a GE side by side model # gss27rgmf cc. The food area is freezing, and the waterline appears to be frozen. Based on the answers given to similar problems n this forum, I am inclined to believe that the issue is with the damper. I am getting ready to order the necessary parts, I just want to make sure that this is really the problem, or that it could be something else entirely.
Thanks.
    Champion:
  • 210 Answers
Sounds like the damper- check voltage to damper motor.
Posted on Jul 22, 2008
Lfx25971 will not dispense water
My water dispensor INSIDE the door froze up.... GE
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Jun 08, 2012 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Will not dispence water
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Ice maker and water dispensor not working on GE profile model 26...could it just be a frozen line?
yes.........unless the waterline from the house hookup ie--saddlevalve is plugged follow the waterline from where it hooksup turn to close all the way!!! then turn it back on see what that does for you because if the saddlevalve is hooked on the bottom of the waterline it could have gotten plugged over time
Aug 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Refridgerator Not Dispensing Water
The waterline inside the door is frozen . Best way to thaw is .....1. open the door and tape the light switch down to keep the light off and the fan working . 2. tape plastic (trash bag , drycleaning bag..etc) over the entire freezer opening so the food will not thaw and the fridge will continue to work as designed . If possible 3. disconnect the water coupling behind the kickplate so air can enter , helping the door defrost cycle , or , leave the coupling connected and ocasionally walk by and press the water dispensor to see if thawed . 4. turn your freezer setting to a lower temperature ! to keep this from happening again .
Jul 10, 2009 | GE GSS25SGPSS Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
239 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
