Question about Magic Chef CTF2125 Top Freezer Refrigerator
There is a huge puddle of water under the front of the fridge ,this unit doesn't have an ice maker what could this be ?
  • 121 Answers
The drain is clogged. You will have to remove the back wall of the freezer to access the drain. There is a hole under the coils, that is th drain. Remove the ice on top of the drain and clean the drain out by forcing hot water down the drain with a turkey baser untill water flows freely. Then mix baking soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Posted on Sep 28, 2010
  • Tracie Sep 28, 2010
    thank you so much :)
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
Water puddling in bottom of fridge. water is
If the water to the ice maker is off then the source would be the defrost drain. I have put together some instructions on how to clean out the drain so the water will go to the proper place. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 17, 2010 | Electrolux Refrigerators
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water through the door but no water to the ice maker
Since you are seeing the arm up at times, ice maker is ok. Look for problem with water solenoid valve on back bottom of unit
Sep 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
Magic Chef CTF2125 Top Freezer Refrigerator Logo
148 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
