Question about LG WFT1071TP Top Load Washer
My LG washing machine Model: WF-T7016PP rinses the wash load twice. It drains the dirty water after a wash as it should, fills the tub to maximum (regardless of the wash load volume) and rinses the wash load before draining the water. IT THEN FILLS THE TUB TO MAXIMUM AGAIN and does another rinse cycle before finally completing the the job with a spin cycle. THIS WASTES A LOT OF WATER as only one rinse is necessary. Is this the way the machine was engineered to function or does this indicate a problem with my machine? I have tried both FUZZY and JEAN modes but the same double rinse sequence occurs.
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
  • 1462 Answers
SOURCE: My brand new Lg front
can be
either
inlet valve leaking. turn off water and see if it still fills
or
if drain is plumbed in to a spigot off the sink trap, every time you empty sink, some of the water goes down the drain pipe. to cure in this case, take the drain pipe as high as possible up under the sink in a swan neck
Posted on Oct 18, 2008
ginko
  • 19396 Answers
SOURCE: water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Posted on May 21, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
GodBlessU
  • 3513 Answers
SOURCE: My washing machine that is
Please check the bellow link to troubleshoot your problem to your machine:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#Itwontdrain
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 14, 2010
LG WF-T7016PP. It makes an operational sound, but why doesn't the drum move?
U been had - go back to the vendor regarding that POS.
Mar 22, 2016 | Washing Machines
Lg wf -t7016pp not spinning,why?
You seem to have a broken component in the machine- I would call the LG contact number and inquire there- depending on how old the model, serial number, date of purchase, proof of purchase, you may get replacement parts and a washing machine isnt too complicated to navigate around. Im sure you could fix it :) But wish you the best of luck- If not- Second hand shops that sell these devices are usually very knowledgeable and for a small fee- you could have it working in no time.
Aug 11, 2014 | LG Washing Machines
Wash a sheep skin cover now the machine will not drain water as it usually did...it is an LG WF-T7016PP
The hose from the tub to the pump or from the pump to the drain hose is blocked, remove and clear blockage.
Aug 19, 2013 | LG WFT1071TP Top Load Washer
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Jun 04, 2010 | LG WM2277H Front Load Washer
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
206 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
