Question about Garmin nuvi 1300 Car GPS Receiver
Garmine Nuvi 1300 won't acquire satellite. - Garmin nuvi 1300 Car GPS Receiver
  • 12 Answers
SOURCE: won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Posted on Dec 09, 2007
  • 35 Answers
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Posted on Jan 21, 2008
SOURCE: Dont Aquire Satellites
Ditto.. even after updating FW...
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: Garmin Nuvi 360 - Acquiring Satellites
I had a problem with my Nuvi 360 that it couldn't find the satellites. I couldn't solve the problem with resets or updated software, but a new, external antenna that plugs into the side of the folding antenna seems to have solved the problem. Available from Wireless Finest through Amazon.com - like $11.50. Great solution - can't beat the price.
Posted on Mar 03, 2009
  • 396 Answers
SOURCE: My nuvi 1300 won't find a satellite
big red
turn it off take it out side for a clear view of sky then turn back on leave for 10 minutes then it will work worked on mine
Posted on Oct 25, 2009
Garmin 1300 acquiring satellites problem
Hello
I have a nuvi 1250 and what i did is i put it on my windshield just below my review miror. [and i am telling you this ]it cut the serching in half. and i think that the radio antena might help but i was told that they do that alot so that they are on top of any problems.
good luck,
Jun 27, 2012 | Garmin nuvi 1300 Car GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1300 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1300 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | GPS
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 1300 will not aquire satellites
This seems to happen quite often with GPS units. There are a few things that could cause this to happen. Is the GPS mounted in view of the sky? If not it may not be able to acquire the satellites. If this is not the problem, try performing a reset by pressing the top left corner of the screen while pressing the power button. These two things will usually help, but in the case that they don't, contact their support at 1-800-800-1020 and they should be able to assist you.
Sep 16, 2011 | Garmin nuvi 1300 Car GPS Receiver
Garmin nv 1300 can't find satellite
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Mar 05, 2010 | Garmin nuvi 1300 Car GPS Receiver
I have a garmin nuve 1300.. and it keeps on saying aquiring satellites i have tried all aspects of trobleshooting... can u suggest anything different
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Feb 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
1,456 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
