Question about Ingersoll Rand G1A200RS4 Pneumatic Sander
Trying to find an air control valve for a rockwell 2205 type 2 air sander. can you help me
Where do i find a dust bag for a rockwell belt sander model rc4355k
If you have the instruction book there could be an exploded diagram and parts list and instructions where to buy spare parts.
You could ask the retailer where it was bought.
You could try the manufacturer's website.
Failing those options there are lots of websites providing a spare parts service for power tools. Just google spare parts for your model of power tool...
Oct 24, 2016 | Sander Tools & Hardware - Others
I would like a pdf copy of the manual for a Rockwell 361 belt sander?
this covers the 361
some one loaded the instuction booklet side ways
page 6 is the belt fitting
14 pages
http://www.manualguru.com/rockwell-sonicrafter/361c/users-manual/page-4
Apr 29, 2016 | Tools & Hardware - Others
I need a parts list for Rockwell Jawhorse rk9002
Unable to find a repair parts list, and the manual does not provide much help. The manual does list a support number that you may wish to contact, especially if it is still in the 5 year warranty period. Rockwell Helpline 866-514-ROCK(7625)
May 26, 2015 | Rockwell RK9002 JawHorse Sheetmaster hold...
Sander won't shut off
Most likely the throttle valve is stuck open. On sanders usually sanding debris has coated the throttle valve pin, causing it to stick. Other times the throttle valve seal has worn and needs replacement.
Mar 17, 2014 | Ingersoll Rand 311a Air Dual Action Quiet...
Slow to start oscillation, at times will eventually get to high oscillation. any suggestions or resolutions ?
I solved my problem , by taking it into pieces and found the bearing needed to be clean with super penetrating lubricant PL-100, then blowing air. Now ,work like a new one
Sep 25, 2013 | Rockwell Speed Block Sander Model 330
Need new throttle valve
I just looked on ebay you can buy the orbital sanders for as low as $10.00 Even the Black and Decker is around $ 15.00 Cheaper to replace than to keep. Good Luck https://www.youtube.com/watch?v=Ff8iYu7JXvA
Nov 05, 2012 | Tools & Hardware - Others
Extreme Vibration in my Porter Cable (Rockwell) 330 Sander
I also have had this problem and I found that if I hold the unit tightly and squeeze the plastic housing the RPM's will stabilize as the unit warms up. Best fix is to replace the rubber isolators that prevent vibrations from the motor from reaching the plastic housing. The isolators have become hard through age or very cold temperatures.
I read somewhere that keeping the sander stored in a warm room can also help because when the rubber is very cold it becomes hard.
Oct 07, 2009 | Porter Cable Porter-Cable Speed-Bloc...
Hi,my main problem is locating a schematic for the rockwell sonicrafter rh5102k
Go to Rockwell.com & ask the technicians for your chematic product.
Sep 29, 2009 | Tools & Hardware - Others
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
Ingersoll Rand G1A200RS4 Pneumatic Sander Logo
132 people viewed this question
Top Ingersoll Tools & Hardware - Others Experts
Mike
Eddie Tucker
Level 1 Expert
Lawrence Oravetz
Are you an Ingersoll Tool and Hardware - Other Expert? Answer questions, earn points and help others
