Question about Microsoft Windows XP Professional
Error ID=0xC00D119A, Condition ID = 0x00000000 Web Help
    Scholar:
  • 64 Answers
This is a noted common error going back to the early 2004....
This error message (Error ID = 0xC00D119A) means that Windows Media Player was unable to download a Codec it needed to play the file you were trying to listen to.
Beacuse windows media shares your internet settings, I'd start by going to IE's tools->internet options menu
Check the Security tab for internet and go to 'custom level'. See if 'Allow file downloads' is checked - if not, check it, OK out, restart IE and windows media and try the codec download again.
If it works you should be able to set your IE security back to 'refuse file downloads' until you need it again.
good luck ....
Posted on Sep 28, 2010
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
Sound problem
reinstall your sound card driver using the driver cd that came with the system. download Media Codecs. if same hing happened. you an download VLC player to play you video file instead of using media player.
Apr 04, 2010 | Computers & Internet
Error ID = 0xC00D11BA, Condition ID = 0x00000000 occurs when playing audio
http://www.tech-archive.net/Archive/Media/microsoft.public.windowsmedia.player/2008-08/msg00136.html
Nov 17, 2009 | Computers & Internet
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors...
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Nov 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
Sound device trouble shoot problem.i can't
very simple you are change sound card or system driver or audio cable
or correct path of audio cable or instal new window and reinstal newdriver
Sep 07, 2009 | Acer Computers & Internet
this should help steve.
Feb 27, 2009 | Computers & Internet
Problem in getting sound
Check does you sound driver is install OK!!! If not
(right-click My Computer -> Manage -> Device Manager) for unknown/improperly installed devices.
Visit you SOUND manufacturer’s website, and download drivers along with the installation instructions!!! After that it will work just fine!!!!
Jan 23, 2008 | Computers & Internet
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Microsoft Windows XP Professional Logo
403 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
