Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Looking for "kit" to install w/Genie garage door opened that would operate on battery if power is off
    President:
  • 3,197 Answers
This is not available as a kit. The motor in the models that do have this function is special.
Posted on Sep 28, 2010
What is the battery size for a genie garage door remote opener model gict390
The GICT390-1 (one button remote) and the GICT390-3 (three button remote) both use a 2032 coin cell battery.
The manual for the GICT390-3 is available from Genie on their Programming Accessories page: http://www.geniecompany.com/garage-door-openers/programming_accessories.aspx . The direct link to the instructions is: http://www.geniecompany.com/data/products/accessories/manuals/legacy/36484U_1-Btn%20IC1,%20390_3577435796.pdf .
I hope this helps.
Feb 25, 2015 | Televison & Video
Can I use a chamberlain remote with a genie pro garage opener
you can try to see if it works but probably no- get anather genie remote
Oct 02, 2014 | Chamberlain 953cd multi-function 3-button...
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Battery does not last
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Aug 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
