Question about Clarke Power Products Clarke 16-Speed Drill Press with Laser Centering Device # BT102
I have a clarke drill press model BT1001 or 13167. I need to get a chuck that fits it. Any suggestions?
3 Suggested Answers
  • 2976 Answers
SOURCE: hi, I have a Clarke Drill Press Model No:- CDP 12HBN
You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
Posted on Nov 24, 2009
  • 90 Answers
SOURCE: I need a chuck key
you should be able to find a universal key that has four keys on it. ace hardware or local hardware should have it. if not call your local tool store to see what they have for similar chucks.
Posted on Sep 01, 2010
Removing chuck from a sears & roebuck model 113.24611 drill press
It is a morris taper wedge fit, so just tap it out.
Dec 29, 2016 | Sears Drills
I have Clarke metalworker model bt1001a drill press, looking for a manual and chuck key, were can I get one?
chuck keys can be found at amazon for good prices, take a look here: Amazon com chuck key. I hope this was helpful. Cheers
Oct 29, 2012 | Drills
WHEN DRILLING UNDER LOAD, THE CHUCK SLIDES DOWN OFF THE TAPERED DRILL PRESS SHAFT
it needs to be reseated and to do that you will need to clean the shaft and the internal portion of the chuck with something like brake clean and use a paper towel to wipe off the residue, then move the table out of the way and get a block of wood and hammer, retract the jaws fully and position the chuck and put the block of wood under it and strike it with a hammer a couple times this should take care of your problem
Sep 01, 2011 | Clarke Power Products Clarke 16-Speed...
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
I need a chuck key for my Clarke 5/8" drill press, model BT1001. It's quite old but still works well. My only problem is I've misplaced the key, making it very difficult to change the bits. Thanks.
Sep 01, 2010 | Clarke Power Products Clarke 16-Speed...
Chuck for a Clarke hammer drill
Any 1/2 chuck with the same base on it. Are you sure you need the chuck or the chuck key?
Feb 28, 2010 | Clarke Power Products Drills
I have a Clarke BT 1001A and need a new chuck. The original never worked properly. Kept jamming. Where can I get a new chuck. 1/2 inch. The drill press is great.
you should be able to look in the phone book under tools repair find one locally, on the chuck you have it should give you some number like 33BA or 2 Jacobs, you will need this information to make sure that you get the right one, I would try and find a Jacobs chuck for this, they make the better ones, I have used them as replacements for 26 years and the companies that I worked for prefer them. Let me know if you have trouble finding one and I would need that information also.
Feb 07, 2010 | Clarke Power Products Clarke 16-Speed...
Hi, I have a Clarke Drill Press Model No:- CDP 12HBN
Nov 24, 2009 | Clarke Power Products Clarke 16-Speed...
Chuck key
As a start, use drill bit that fits into blind hole in chuck, note size and find chuck key at hardware with same diameter
Oct 26, 2009 | Clarke Power Products Clarke 16-Speed...
I have lost the chuck key where can I get a new
Go to your Ace hardware store ... if they dont have one on the shelf, they can order any size you need. Go with the make, model etc of your drill.
Let me know if this helps you
a
Sep 21, 2009 | Clarke Power Products Clarke 16-Speed...
Clarke Power Products Clarke  16-Speed Drill Press with Laser Centering Device # BT102 Logo
135 people viewed this question
Top Clarke Power Products Drills Experts
Are you a Clarke Power Products Drill Expert? Answer questions, earn points and help others
