Question about Technics SA-DX940
When I turn on unit, a message "overload" appears.
  • Technics Master
  • 17,129 Answers
Check the speakers and the power supply for any signs of shorting.
This is due to the fact that the safety circuit works to switch off the set preventing a high damage.
So check the output for short or the presection .
Posted on Sep 28, 2010
  • tasia0119 Aug 14, 2011
    my problem is the overload does come on after u turn the volume up so high my other question is the fan on the back is it susposed to blow in the stereo or out of the stereo
Got a technics SA-DX1040 and the overload is on, disconnected all speakers and still wont go off
Posted on May 01, 2011
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
Aug 19, 2016 | Sewing Machines
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
I have a Noma Digital Decorating Instant Light Show Timer and I cannot find the instruction sheet on how to use it. It has 19 preprogrammed light shows and the display shows OL and will not let me reset...
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Dec 02, 2011 | Hardware & Accessories
Protect message comes on and my radio doesnt work.what should i do?
Firstly, are you able to remove the head unit from your dash?
Usually, when PROTECT appears, the unit has detected a short circuit (or overload) somewhere, and has shut down to prevent damage.
Problems in the wiring (e.g. loom or speaker wire) can often cause this condition.
I recommend you have someone remove the head and:
- check the fuse in the back of the head unit.
- disconnect one speaker wire, then turn unit on to see if Protect message comes up.
- do this with all speaker wires, until the unit operates without going into Protect mode.
If the above does not solve the problem, then you may need to decide whether repair is viable, or to replace.
Jul 12, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
My Pioner Receiver VSX 918-V get turned off after the OVERLOADED message.
This is similar to a protect message on other units. See the link below for an explanationm of protect. If you have more questions please update this. Any additional details about when this message appears would be helpful as wel.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Jan 27, 2011 | Pioneer VSX-918V Receiver
An error message stating that the device overloaded the usb port appears (yellow light at the port).
Go to the device manager and uninstall all usb devices. Turn off computer, unplug all usb, reboot twice, plug usb in again. Also helpful are troubleshooting usb articles here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 21, 2009 | HP PhotoSmart 7960 InkJet Printer
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
Overload signal
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Mar 02, 2009 | Technics Audio Players & Recorders
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
Technics SA-DX940 Logo
800 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
