Question about Ricoh Aficio SP C231SF Color All-In-One Laser Printer
RICOH, SP C231 - I have error message SC542, what do i do to clear?
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
SOURCE: SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Posted on Mar 31, 2008
mimranon
  • 72 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
Posted on Apr 20, 2009
Ickoajnc
  • 203 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
I want to clear a sc542 message on my ricoh aficio sp c410 dn
hold down the up and down arrows for 5 or so seconds release and hit the # key cycle power. -Carl
Sep 14, 2017 | Ricoh Office Equipment & Supplies
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 28, 2014 | Office Equipment & Supplies
My printer multifunction Aficio sp C240sf show the error message sc542
For this model specifically, the following will get you into service mode.
Hit "Clear / Stop" Buttom then "107" then hold down "color print" buttom for some sec then you are in service mode
If that doesn't work, you can also use Clear/Stop,1,0,7, Clear/Start.
Each key should be pressed and held until you hear a beep
Sep 09, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
Apr 21, 2009 | Office Equipment & Supplies
Ricoh Aficio SP C231SF Color All-In-One Laser Printer Logo
1,078 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
