Question about Keurig Elite B40 Coffee Maker
All LED lights flashing and the brewer does not work
I have a new Keurig B40 that I used for two weeks. It now has all the LED lights flashing at the same time and does not brew any coffee. I have not been successful in "resetting" the brewer. Any help would be much appreciated.
  • 11 more comments
  • Anonymous May 26, 2008
    The problem has also happened to me. After spending almost $100 I am really pissed off that the brewer just stopped working. It seems that no one seems to know about the problem in at Keurig customer support.
  • kris856 Jul 04, 2008
    ME TOO! I'm so frustrated.
  • Anonymous Jul 15, 2008
    I have the same problem. Keurig support asked me if there's been an electrical storm (no) and they are sending me a new brewer and sent prepaid postage so i can send the old one back... While I'm not happy that it broke, the cs seems pretty reasonable.
  • sb_chatman Oct 19, 2008
    I have same problem with my Keurig B40. Had one stop after 3mo. and cs @ Keurig sent out another B40, only to brew 5 cups and stop working again. Very frustrated but love the product. Will keep you posted on what they say.
  • hreadey Oct 26, 2008
    Followed priming procedure in maunal and it primed okay. Before I could make a first cup, all LED lights started flashing. No action on may part including depressing buttons, removing/reinstalling full water reservoir, or opening and closing the K-cup holder helped. I also unplugged the brewer and after a minute plugged it back in. LED lights continue to blink weh when the unit is plugged in.
  • Save7 Dec 09, 2008
    My brand new B40 started flashing just after starting the priming process. No water ever left the holding tank.
    I've left messages, emails and just finally got a hold of a customer service rep only to be told that I'd have to call back when I'm in front of the machine as they are not allowed to give me the sequence by email or phone since it is proprietary information. WOW!
    This is frustrating - I WANT TO USE IT!!!
  • stormtco Dec 30, 2008
    I am so mad.. I just bought it made two cups and now I have the same problem with the lights flashing. I called customer service but need to speak to a tech between 8 and 530 so now I have to go to work late to try to fix a coffee pot that I spent 100.00 and yet to use...
  • anonym12345 Jan 01, 2009
    How do you press the auto/off button and the small cup button at the same time? Any help would really be appreciated.
  • Anonymous Jan 15, 2009
    I need the sequence to reprogam my keurig Ultimate
  • Anonymous Mar 16, 2014
    How to descale a Keurig coffee brewer
  • Anonymous Mar 23, 2014
    ...when the coffee brewer's power, "on," button (on top of machine) is depressed, the light under the button (indicating power is being delivered to the machine) does not respond. The brewer is indeed not receiving electricity. This is not a house wall outlet or electrical supply issue. The unit just quit powering up.
    when the power "on" button is depressed, the unit does not power up...this is not an electrical supply (house wall socket/electrical supply) issue, as the unit worked one morning and would not power on the following morning...
  • Anonymous Mar 25, 2014
    I have a Keurig B-30 and it will not brew. The power light comes on but nothing else happens. I have cleaned the needles with a paper clip and have turned the unit upside down and slapped it a few times. I have used compressed gas to clean the tubes. I cannot run anything through the brewer since the opower light comes on but nothing else works.
I had the same problem. They told me it had to be "reinitialized" To do so, press the auto-off, small, and large cup buttons simultaneously then release. All lights should go off. Unplug, replug, then press power and it should work again.
Posted on May 03, 2011
  • cristen_king Aug 13, 2011
    Perfect... Worked great, Thank You very much!
  • Chadashpaugh Nov 23, 2011
    This worked first time after trying the up,down,left,right,a,b,start technic. Was refreshing to push 3 buttons unplug plug in and brew. So thank you
Just got my fixed from tech support... the following is the procedure that works:
1. Hit auto off and small cup at the same time and release hit small cup three times, when it works the only light showing will be the descale light....
2. hit small cup then auto off, then release small cup and then auto off, when this works lights on will be the power button light and the descale light.....
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY....
3. With both of the above lights on unplug for about 3 to 5 seconds... and then the brewer comes to life.. and WORKS
I am now drinking a great coffee brew and enjoying it... This does work, but you have to push the buttons in the sequence I have listed and FAST!!!!!!
Posted on Feb 25, 2009
I had the same problem w/ mine- just received it a couple days ago. I e-mailed Customer Service thru Keurig.com and they e-mailed me back to call their Service Dept between 7AM-12 Midnight EST and to make sure I had the serial # (located either underneath the base or behind the drip tray-just pull it out) when I called.
I tried the troubleshooting sequences mentioned above before calling and it didn't work. Still had all lights flashing.
Hold down the small cup and auto off at the same time and release. Do this in one quick motion.
Next, hold down the small cup then auto off and release small cup, then release auto off buttons. As mentioned in a previous reply, this has to be done FAST.
If the reset is successful, only the power light (solid green) and the Descale (blinking) should light up. It took me 3 tries to get it right, so be patient.
Unplug for 3-5 seconds and then plug back in. Power light, Heating, and Descale should be lit.
Make sure you have water in the reservoir and an empty cup to proceed w/ Descale/ Setup instructions that were included in the manual. They will talk you thru it if you don't have it handy. The Heating takes a few minutes, but you'll know if it's happening because it makes some noise.
She assured me that this would be a one-time-thing when I asked her if I wrote all of the steps out correctly.
If this doesn't help, the Customer Service # is 1-866-901-2739.
Good Luck!
Posted on Feb 14, 2009
  • 1 more comment
  • redlodge Nov 21, 2010
    this was the trick. the rhythm is the tricky part but keep trying it and it will work
  • rickosmonson Nov 29, 2010
    This worked great! Thanks for the info
  • Houdini126 Apr 06, 2011
    Very helpful got it working great.. bought it for ten dollars because the previous owner thought it was broken!!
I held down small cup large cup and power button down at same time and it reset.....
Posted on Dec 28, 2009
Try quickly pressing (at same time) small cup button & the auto off and then you must immediately press the small cup button three times. We had to do this combination very fast.
1) together & fast: small cup button & auto off button
2) immediately press small cup button three time fast
Posted on Dec 27, 2008
I just had this happen this morning, I tried all the above mentioned programming nothing worked...I was avoding haveing to call customer support so I just started pushing buttons.
I held down all three buttons together and the lights went out.
I unpluged the machince pluged it back in just to make sure it didn't start again, and then made a cup of coffee. :)
Posted on Jan 21, 2010
I randomly pushed all the buttons on the top numerous times. Finally after several minutes of pressing something evidently reset and it started working.
Numerous= very fast and radomly, I guess I accidently hit the right sequence.
Posted on Dec 25, 2008
I wrote it down from what i remembered after talking to a tech rep..hit small cup button and auto off button same time then let up and hit small cup button 3 times. all this has to be done fast. then hit small cup button and auto off button again together then let up and hit small cup button just after that and only hit one time. then unplug wait a few seconds then plug back up. all lights will be off then hit power button. descale light will be lite then hit small cup button and heating light will light up, it takes a couple of minutes for water to pump from reserves to heat up and then water will come out in cup and then its primed. And i'm pretty sure thats the way it went.
Posted on Dec 30, 2008
I could not get any of the methods above to work. I got fustrated and pressed both the small cup and auto/off buttons simultaneously, about 4 or 5 or 6 times in a row, very quickly, in response to my extreme fustration and anger (who would design something like this? where is the reset button??)... Until I noticed all 5 LEDs were on but dim (they are blinking very quickly, making them appear dim). Then, I stopped, realizing this is 1/2 the battle. Now, I either pressed small cup then auto off, or just small cup. Cannot remember. Try something. The first time I had the dimmed LEDs, I did not hit the right sequence. But was able to get the dimmed LEDs a second time, and figured out what to press once you got the dimmed LEDs. Anyway, I basically tried solution #2, and mixed in Solution #2 above, and got it to work. It was Sautrday morning, and I was not going to be able to talk to a service tech during their hours, since I am at work during those times. I wanted my coffee NOW! GEEZ.
Hey, thank you, people here at FixYa. This was great. Thank you for making this website.
Posted on Jan 09, 2010
I press small cup ,large cup, and power unplug
Posted on Dec 29, 2011
A modified version of solution 6 worked for me. I did not do it very fast. I suspect that doing solution 2 very fast results in something very similar to solution 6 (at least for the processor, which can only sense the buttons every x ms): 1. Hit auto off and small cup at the same time and release hit small cup three times. Contrary to solution 6, the only light OFF was descale then. I didn't do that extremely fast. Probably took 2 seconds in total. Was reproducible. Did it at least 5 times.
2. Hit small cup then auto off, then release small cup and then auto off. When this works lights on will be the power button light and the descale light.
What crazy mind would design a machine like this? Probably some brain dead engineer somewhere in China, and Keurig is dumb enough to buy their ****. Will never buy a Keurig again.
Posted on Aug 28, 2011
  • 1 more comment
  • maximilianh Aug 28, 2011
    Why is this website replacing the word s.hit with **** ?
    Strange, in comments it won't replace words with ****
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
Keurig b40 pump out of sync
PLugged exit port tube. Manual Page 18
Jun 24, 2012 | Keurig Elite B40 Coffee Maker
Keurig elite b40 cup lights don't flash. Both are illuminated solid.
Lift the handle to open the k-cup holder and then close it back up. The coffee mug lights should begin to blink for you.
Nov 27, 2009 | Keurig Elite B40 Coffee Maker
Keurig B40
If the machine is new, call keurig.. There telephone number is on the web site. They are warrented for 1 year.
Aug 16, 2008 | Keurig Elite B40 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
5,344 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
