Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
I get a "input signal out of range" with windows nt. Is it my frequency or resolution settings and can I correct it?
  • 27 Answers
Well it is maybe the video cards fault. But you could try installing windows xp or newer or older video drivers
Posted on Sep 28, 2010
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
The input signal out of range on screen persists in spite of all monitor and PC video settings being correct.
Have you tried uninstalling the graphics driver entirely and then rebooting? Could be a corrupted driver.
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Out of Range problem with LED 19 inch viewsonic monitor
What is the source for the signal to the monitor? First, if the source is a computer, was the computer previously connected to a CRT monitor? If this was the case, you may have the wrong refresh rate as well as the wrong resolution being sent to the video port. Reconnect the computer to the old monitor (if possible) and reset the refresh rate to 60 Hz.
Next connect the monitor to the computer with both devices off. Then turn on the monitor and set it to the correct input (if needed). Then turn on the computer. Most versions of Windows should determine the best resolution for the monitor. (Some Unix versions and recent versions of the Mac OS will also automatically find the correct resolution.) If you are still getting the out of range message, you need to change the video resolution with a different monitor connected and then retry. Always turn on the monitor first.
For additional support, please add a comment with the specific monitor and source that you have. In a few cases, the video card/on-board video may not be able to output the correct resolution or lose the correct setting when the monitor or computer "sleep".
I hope this helps.
(I've seen most "out of range" messages with several TVs that were connected to computers and turned on and set to the computer input after the computer booted up.)
Aug 12, 2012 | ViewSonic Computers & Internet
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Inout signal out of range Answer Failed: retry
It shows out of range because the PC is sending out the video signal that is higher than the monitor can display, you need to set the PC video resolution to the native resolution: 1024 x 768 @60Hz. You can reboot the PC into save mode (hitting F8 key while booting up) then set the resolution to 640 x 480 (try 1024 x 768 if it allows you to do so), reboot and reset the resoltion to 1024 x 768 @60Hz.
Mar 06, 2010 | IBM ThinkVision L151 15" LCD Monitor
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
Input signal out of range
You could try going into safe mode and make sure the correct drivers are installed and if they are then you can then set the correct resolution.
Feb 28, 2009 | Dell OptiPlex GX260 PC Desktop
Cannot remove "input signal out of range"
input signal out of range would normally indicate the the screen resoloution is either too high or too low for the monitor to display properly.
is this on just one game? which version of windows do you use?
Jun 21, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
206 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
