Question about Roper Washing Machines
Washer will not spin out....acts like no power...wases fine ?
  • Roper Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 28, 2010
Wasing machine washes fine, once it gets to the spin cycle it stops and just makes a slight hmmmmmm sound. and wont drain or spin.
Wendy,
What brand of washer do you have? If you put that info in, it did not come through with your question and we need that info to give you the correct information to help you fix your problem.
Jun 23, 2015 | Washing Machines
The spin/drain cycle are leaving the clothes wet after wasing almost all the time.
Hi kerry_coorner,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wasing machine stops spinning during final spin - 3 or 4 minutes into the cycle.Frigideaire front end loading washing machine.
You could be using too much soap that will cause the machine to go in oversuds motor protect and shut down . Do make sure you are using HE soap and only about 2 to 3 table spoons per load .The next most likely cause would be the door lock but I think you have a soap problem..Good luck need more help please ask Thanks for Voting
Mar 13, 2011 | Frigidaire ATF6000ES Front Load Washer
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
WHEN EVER THE MACHINE IS RUNNING, ESPECIALLY DURING THE SPIN CYLE, THE WASING MACHINE MAKE A VERY LOUD NOISE AS IT ROTATES. IT ALL MOST SOUNDS LIKE IT RUBING AGAINST SOMETHING. ANY...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 18, 2010 | Washing Machines
GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
Amanna wasing machine 3.2 cu. ft. top loader
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
Oct 07, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Samsung fuzzy wasing machine WA75N6
sad to say, he is correct. when all indicaters come on together and do not extinguish, the board needs to be replaced
Aug 07, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
