Question about Canon DC10 DVD Camcorder
Cannot eject finalized disc
When I move the power switch to camera and push the open button, the disc cover does not open. I hear four clicks and then no open. The record pause indicator in the upper right corner of the lcd is on. Is this normal for a finalized disk? My disk is a dvd-rw type. Thanks for any help.
Try turnin the camera to the side where gravity will help pop open the disc and be careful not be keeping it close with your own hand. Its a thin cover and you can accidently be holding it close without knowing.
Posted on Nov 01, 2008
My PS3 80Gb shows the red standby light as normal. When I push the power button, I hear one beep, as the light go from red, to green, to off, and then finally back to red again. If I push the eject button...
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Feb 03, 2011 | Sony PlayStation® 3 (80GB) Console
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
Probelm ejecting the dvd from my Hitachi GX3100A
If you go to the Hitachi website, you can download the product manual for your camcorder there.
These are the instructions for opening the dvd door.
1 Press down the DISC EJECT button once and
release it.
A few moments after the ACCESS/PC
indicator blinks, the cover of disc insertion
block will open.
2 Gently open the cover by hand fully until it
stops.
This is the link for the owners manual search: http://www.hitachionlinestore.com/survey/manualsearch.aspx
Hope this helps.
Apr 29, 2009 | Hitachi DZ-GX3100A DVD Camcorder
I can't my Disc to eject from my Wii Console. Does anyone have a solution to this problem, other than taking it in for service?
Try all of these steps:
1. Turn the Wii off and on again after about 20 seconds. Press the eject button again. If no help:
2. Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. If no help: 3. Hold down the eject button for 5 to 10 seconds. Still not: 4. Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. if no help: 5. See if power light was coming on and do the AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for 5-10 seconds Finally: Call Nintendo 1-800-255-3700 and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Good Luck
Mar 03, 2009 | Nintendo Wii Console
Door won't open
Those kind of problems just require that the door open one time. However, to do that you will have to take the cover off the player with the power off of course. Once you have take the cover off ( only a few screws ) you will be able to see the disk player well enough to see the back part of it. There are two ways you can do this, first, is to power the player back on, press the power button on. Then when you press the open door button or use your remote whichever, have your finger on the very back end of the carriage that holds the disk and push to the front gently as it tries to open the door, you will know because you will hear a short click from a relay. If you cannot open it after a couple of tries then power it off again and unplug it. There are only four screws that hold the disc player part in itself. Take those four screw off so you can lift it far enough to get to the bottom front of the disc player. Once you can do that, without the power on, there is a white neoprene part that moves from left to right or right to left to open and close the door. You will be able to see it and you can manually slide the part to whichever side it will move and that will open the door. You can gently push the door back closed and open it again a few times. Then place the disc player back in place with the screws in and power it up and open the door with the remote or button. It should open. What happens is that depending on how long the player has set on a wharehouse shelf or just around even if it is new, the lithium grease that they use for the moving parts dries out and it needs a little push and use to work properly again. Let me know if I can help in any other way.
Feb 09, 2009 | Sharp BDHP20U Blu-Ray Player
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Broken button
you could finalize your disk on a computer OR if you have the automated edition series, you can push the auto eject button and it will finalize and eject your disk
Feb 24, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Canon DC10 DVD Camcorder Logo
203 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
