Question about Sony Handycam DCR-TRV16E Mini DV Digital Camcorder
When playing back tapes they have grey lines over pictures,why is this? what can be done?
  • 4,234 Answers
This is usually an indication of digital dropout. Try using a cleaning tape to clean the heads. If that fails to resolve the problem, have the unit cleaned professionally.
Dan
Posted on Sep 28, 2010
Why doi have grey lines across my Sharp camcorder VL z7 when It on play back. Theres sound breakage as well. Can someone tell me why?
Do you get the grey line when you play back incamera ?
Have you transferred the file outside the camcorder ?
If you get the grey line in both, invariably the recording head needs cleaning.
Power on the ViewCam.
Eject the tape.
Use a soft lint free cloth and generally clean the head.
The head of the large metallic cylindrical thing placed slightly titled.
It is right at the bottom of the camera beyond those small posts.
If your finger cannot approach, use a swab with mild spirit/alcohol.
Let it dry a minute and then record a fresh material and try.
Please reply if it helped or not.
May 02, 2014 | Sharp Viewcam VL-Z7U Mini DV Digital...
On my cannon digital video camcorder ( model MV730i) i am trying to play back some footage i have taken but on the view finder (and also on my computer when i transfer footage over) the picture is coming...
Possibly dirty head and/or dirty tape.Maybe even wear-out tape,too.
But the worst scenario would be faulty or damaged head,which would be not worth repair it.
Aug 19, 2010 | Canon MV730i Mini DV Digital Camcorder
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Grey Lines across video display
Same thing is happening to mine, it's not the minidv because i tried that one on a diffrent camera and it works fine. It's got to be a setting or something. If anyone can figure it out, that would be great.
Sep 01, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Horizontal grey lines running whe camcorder in play mode
Its symptoms of dirty / clogged video head. Please use Sony video head cleaning tape to clean video head.
Jan 28, 2009 | Sony Handycam DCR-TRV140E Digital...
Canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Jan 13, 2008 | Canon ZR100 Mini DV Digital Camcorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Jul 16, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Sony Handycam DCR-TRV16E Mini DV Digital Camcorder Logo
98 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
