Question about Honda Garden
Model 2600 XR 2625 Excell, not enough pressure, leaking water, underneath, in front of engine. Runs well, all areas clean of debrei.
kel1guy2002
  • 3740 Answers
SOURCE: I have an Excell Pressure Washer Model VR 2522, it
Hi and welcome to Fixya. Your model has the A14527 Pump assy on it and they are notorious for the pistons leaking due to blow by and the 16 MM seal on the piston starts to leak near the drive shaft.
In addition the O-rings #2950 that mated the piston housing leak. Add to that the 4 o-rings that mate the pressure head to the pump also leak.
See this manual:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/A14527/A14527.pdf
There are a BUNCH of parts in this pump. One mistake and it will not work when you get done working on it. Be careful what you disassemble.
The seals that leak are items 4, 15 and 16 in the manual.
There can be other leaks.. the ones I pointed out are the most common.
Thanks for using FixYa.
Kelly
Posted on Apr 13, 2010
Editor925
  • 285 Answers
SOURCE: What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Posted on Jun 15, 2009
SOURCE: Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Posted on Jul 22, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
deme-tri
  • 90 Answers
SOURCE: no water pressure on my honda 2600 excell ic2
you need to check the valves,
there is a possibility that the springs are rusty.
Posted on Dec 03, 2009
Excell xr2750
excell does NOT make the engine. telling us the engine information might help better but RARELY is it a timing issue. check for spark, if you have spark then shoot carb cleaner into the carb... does it start ???
Nov 27, 2013 | Garden
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
Honda XR 2600 pressure washer, cord will not pull on engine
This is typically due to the unloader bypass valve not operating properly. You can remove and clean this valve or you may want to replace the valve with a new one.
If you take the high pressure hose off of the pump and with the water turned on you can start the engine each time then you probably should replace the unloader bypass valve.
Here is a link to the pump.
http://www.allpartsinc.com/mmAllParts/Others/A14292-001.pdf
Oct 08, 2012 | Honda Maxus Pressure Washer MX5222
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
How can i tell if my waterpump is bad? shut the car off and came out later to anti freeze in the driveway
If it's leaking that bad, open the hood take off radiator cap and fill with water (without making a mess and spilling a bunch. Then simply watch for where the leak is at, if it's leaking from a hose, the radiator, or from around the area where the belt is located on the passenger side of the engine compartment. If it's leaking from the passenger side around the belt area your water pump is the most common cause. They are made so when the bearing wears out around the shaft the pulley bolts, it has what are called weep holes and the water just runs out to tell you to replace the water pump.
Jun 18, 2011 | 2004 Ford Taurus
MY MACHINE STARTED TO LEAK BLACK OIL UNDERNEATH THE PRESSURE MACHINE, I SUPPOSE ITS THE WATER PUMP WHICH WAS RUNNING WITHOUT ANY OIL
If there is black oil coming from the bottom of the pump area there is a good chance it is either coming from the pump or the engine. If the oil is coming through the pump one of the seals is bad.
Unlike most brands the Black Max offers very limited parts for their pumps and depending on what model you have there is a good possibility that the oil seals aren't available. On the other hand, you should be able to find a pump to replace the one that you have at a very good price.
If I knew the model number of your machine I could better assist you in finding the correct replacement pump for your machine.
Oct 20, 2010 | Honda Black Max 2600 PSI Pressure Washer
Honda Excell 2600 no pressure and water is leaking from the pump. i believe it's the unloader but can i fix it myself. i'm handy with tools and repairs but do no have the manual.
a manual will not tell you how to replace the unloader if you have the same unloader you will need a pressure gauge to adjust it at 2600 psi and your spike pressure should not exceed 3100psi and the leak at pump you need to check your oil make sure is not milky and if not you will need seals also
Aug 23, 2010 | Garden
No water pressure on my honda 2600 excell ic2 model xr2625
Nov 15, 2009 | Garden
Garden Logo
453 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
