Question about NEC VT460 Multimedia Projector
My image is back to front can you advice how to alter this
  • 4,234 Answers
I don't have the specific incantations for this, but work through the setup menus and you should see a series of selections for ceiling/floor, front/back etc. This is selectable in that fashion.
I will try to locate the specific menu in the meantime.
Dan
Posted on Sep 28, 2010
Some photoshop photos does not fit in pinnacle in monotage window how can i solve this??
Return to your editing software and resize the images. If you can establish the maximum size that pinnacle monotage will accept, then all you need to do is change the size to make them fit.
The menu command in Photoshop is Image> Image Size. When the Image Size window opens make sure the 'Resample Image' option is ticked. You then have the option to change the size by Pixels or Percent in the top half of the window or dimensions in the bottom half of the window.
My advice would be to alter the resolution to change the size. To do this you must remove the tick against 'Resample Image' and then change the resolution value altering the value until the size you want appears in the document size area of the window. This way you do not loose any data from the image, retaining all the original quality.
Dec 19, 2013 | Pinnacle Computers & Internet
When I put memory stick from my sony DSC W5 into my computer all the photos show. when in the camera half of them are missing and file error shows on camera screen any ideas?
Common error, can be caused by altering images or editing in the computer, then saving the images back to the memory stick, the camera cannot read the edited images or sort out changes that may have been made to the file allocation table on the stick. Download all the images to the computer, back the images up to a disc, flash drive or another hard drive. Then re-format the memory stick in the camera before using it again. The image "workflow" fr digital photography intends for the camera to PC path to be a one way street.
Jan 01, 2013 | Sony Nice Cybershot Dsc-w5 5mp Digital...
Is there a way to define scan area settings in CapturePerfect v3 to allow for different margins when scanning front-side and back-side of a paper? I.e. to compensate for differences in left and right...
Interesting question. I don't think there is a solution from CP3. It is logical to assume that front and back sides are of the same size and hence there is no provision in the software. One option is to scan once for say top side(left margin) and change the settings (select reverse scanning, i.e, bottom side only) and alter the margin as required, nevertheless you will have to scan twice. You can also crop after the images are generated separately, but it is difficult to separate odd and even images, assuming there is a large number.
S. Mohan, Chennai, India
Aug 18, 2011 | Canon DR6050C A3 Document Scanner 60PPM
I HAVE A SCRATCH ON MY LENS, 35MM PLEASE HELP I WOULD LIKE TO BUY A REPAIR KIT.
There isn't one. Polishing out a scratch would alter the shape of the lens and ruin the image quality. Anything which fills the scratch will also alter the optical properties.
Just live with it, even fairly bad scratches are rarely visible in the images taken with a scratched lens although they sometimes catch the light at certain angles. using a lens hood will prevent that.
May 29, 2011 | Canon EF 17-35MM F/2.8L USM Lens
Front is low !!
To alter the vehicles ride hight is a drastic and costly solution. The shock adsorbers will not alter the ride hight as it's the strut assy that determines the vehicles hight, Also ensure there are no excessively heavy items in the trunk . A broken exhaust mounting will lower underside clearences. Check and inspect all mountings. It would be worth measuring your kerd side height with a similar vehicle. I presume you don't mean , side skirts added at a later date on vehicle. Good Luck
Apr 11, 2010 | 1999 Mercedes-Benz E-Class
I just replaced the control board assembly on the front of my icemaker. How long should it take it to start the water filling process?
What is "just replaced"? Have you waited 24 hours? Have you altered the cooling temps?
A little more info....I might be able to give you a little more advice.
Mar 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
I can not understand that what is mask and what is the use of mask in adobe photoshop Please help me pls pls pls pls....................................................................................
Mask is used when you want to protect part of a photograph from alterations you might need to make to other parts of the image.
Masks are incredibly useful for blending photos and hiding portions of images without altering them directly.
Mar 02, 2010 | Adobe Photoshop® CS3 Extended Full Version...
Download from computer to the camera
you can load images onto a card via a card reader, but not directly to the camera. Also images that have been through an editing process in the computer will have been altered so as to be unreadable in the camera- if you were thinking of using the camera to view via a TV for example
May 13, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
NEC VT460 Multimedia Projector Logo
37 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
