Question about Panasonic KX-MB781 All-In-One Laser Printer
COMMUNICATION ERROR, DOCUMENT SCANS, AND GET ERROR
  • 27 Answers
Well i don't know a lot about printers, but i'd suggest to renew its drivers and if that doesn't work then reinstall windows
Posted on Sep 28, 2010
Hp laserjet m1005 mfp scanner error
Have you installed the HP scanning software? (Found on the HP website).
Dec 22, 2013 | Office Equipment & Supplies
In canon ir 2016 there is no scanner movement & also the laser lamp is not glowing & the machine is indicating check document
In canon IR 2016j, if you get error " check document", its a communication error. so you check the flat cables in control board ( is a board in the scanning section)
* Change cable from scanning lamp
* change 2 cables from ip board.
Jun 12, 2012 | Office Equipment & Supplies
I get a communication error after I scan documents with officejet j4680. I am doing this wirelessly. It worked the first two times I did it and then it did not work at all. I can get previews of the...
HP has particluar issues relating to install. Essentially you cannot use plug and play.
Here is what I would do, totally uninstall the printer. Then go to HP.com and download the correct install program for yoru printer and OS. Follow those directions exactly, specifically when to plug in the printer.
If issue remains, contact HP boys directly, via chat and they can straighten you out, usually for free.
Feb 03, 2011 | HP J4680 Office Jet All-In-One Printer
An error ocurred communicating with the scanning
Hi I will be glad to assist you in this issue. here is the libk that will fix the issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00897542&cc=us&lc=en&dlc=en&product=391153
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00040499&cc=us&lc=en&dlc=en&product=391153
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
Scanner error code
This generally indicates a driver error.
Download and run the Scan Diagnostic utility
  1. Download the HP Scan Diagnostic utility .
  2. When prompted, select Open or Run to start the download and run the installer, and then follow the on-screen instructions.
  3. Try the scan again.
The Scan Diagnostic utility checks the physical connection between the device and the computer and address the issues with the following components of the scanning software:
  • PML (Printer Management Language)
  • Yellow DOT4 entries
  • Scan Folder
  • Registry Mismatch
  • HP Digital Imaging Monitor
  • Multiple HP Digital Imaging Monitors
If an error condition is identified with any of these items, a red X ( ) appears next to the item. If there is no error condition, a green check mark ( ) is displayed next to the item. The utility is equipped with a Fix button to correct the error conditions.
Run the Unexpected Internal Error and Communications Failure patch
  1. Download the patch for HP Image zone/photo, imaging unexpected internal error and communications failure.
  2. Double-click the patch to install it on the computer.
Try scanning without HP Imaging software
Try to scan with the built-in feature of Windows operating system called Windows Image Acquisition (WIA). To perform a WIA scan, follow these steps.
  1. Make sure the product is turned on.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon for the product.
    • If there is not an icon for the product, click here to uninstall and reinstall the software .
    • If there is an icon for the product, click the icon, and then follow the on-screen instructions to scan images or documents to the computer.
Sep 21, 2009 | HP J3680 Officejet All In One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
HP 1210 all in one scanner connection error
I found a solution to this...
1. Go to the Windows Start Button
2. Click on Programs
3. Click on Windows Fax and Scan
4. Use that program to scan documents
Apr 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1215 all in one
hello...
- yah you are right there are lots of way how to scan
- first is by clicking the scan button on your printer and if it is not functioning fine then it will give you "no scan options" error message
- 2nd is by using the solution center. then if the software is not installed properly then you can get "an error occured with communicating scanning" or "no hp device detected" error message
- 3rd is to use the scanner and camera under my computer or computer
-- if it is not working then try to troubleshoot the problem here are the links that will help you to fix the problem pls click this link:
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00704&dlc=en&product=412187
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00852647&dlc=en&product=412187
- http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00809848&dlc=en&product=412187
- i w
Jul 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Symantec: Scan engine returned error 0x20000058
this error is due to some file missing in symantec antivirus. u try to reinstall it
Feb 23, 2008 | Computers & Internet
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
Panasonic KX-MB781 All-In-One Laser Printer Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
